Help!!! timing belt problems
Old Apr 9, 2007
kickz's Avatar
kickz is an unknown quantity at this point
hey
i am putting a timing belt and water pump on a 2002 honda civic si
and what happens everything lines up when you turn the crank by hand
every soo often the belt gets VERY loose on the left side from the cam to the crank ..
i have changed tensioner and the spring ..
any ideas ???
Old Apr 9, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
Re: Help!!! timing belt problems
is this an ep3 or candian em2 si? did you put the tensioner and spring on right?
Old Apr 9, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
I was assuming it was a canadian em2 si because I thought k-series only had chains?
Old Apr 9, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
it might be because if you rotate backwards even a little it loosens up. ive seen that happen on a v8
Old Apr 9, 2007
he didnt say anything about rotating it backwards. and what v8's have belts instead of chains? noob
Old Apr 13, 2007
kickz's Avatar
hrmm i got my buddy from honda to take a look at it
he said that was normal
sharp66
31
Jun 12, 2022 08:45 AM
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
