S2000-Civic conversion
Old Mar 6, 2007
Reez's Avatar
Reez is an unknown quantity at this point
Cool S2000-Civic conversion
Hi, fairly new to chatrooms so hope I'm doin' this right... If there's anybody who can help me out with a bit of info on the following I'll appreciate it alot... I'm trying to calculate costs and the feasability of dropping an S2000 motor into a civic '99 model body... What changes do I have to make in terms of gearbox etc. can it be done? and at what expense? Thanx once again... hoping to hear from somebody soon....
Old Mar 6, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
wow uh i havent really heard of this swap done before..however i heard a lot of things about the f series and the k series having a lot of parts interchangeable. but again with some modifications. so if anything best bet would to be the k series with some f series parts. this is something from what ive read. theres an issue with the sedan si with some f sereis parts on honda tuning. its spoon built but yeah. it might give u an inspiration of some sort.
http://www.youtube.com/watch?v=xlra9Yxy9hU
http://www.youtube.com/watch?v=D3bPlvEgM2I
so yeah. it would mainly be a hybrid k20 f20
Old Mar 6, 2007
drunkenmagnum's Avatar
swap can be done. expect to pay at least 8k
Old Mar 6, 2007
jamis33's Avatar
You Stay Classy, San Diego
ok look ive searched this before because i was reading and saw that a s2k could put out 240hp on a N/A 4 cylinder and said wow those guys were thinkin. and if you do search make sure you search the f20C or f22C not to be confused with the f block found in mid 90's accords. They are nothing alike. I think honda just got lazy with their letters. Anyways the site i read basically said that even if you plan on running ur engine N/A the k20 or k24/k20a2 hybrid is a much better engine because it has more potential. They did a test of putting a header and cam gears and some other crap on a f22c and a k20a2 and found out that the k20a2 could make higher numbers with less mods. Also the k20 is a much cheaper engine. The reason why it is better is because the f22c or f20c runs at a higher compression which means its pretty much maxed out and wouldnt do as well on boost as a lower compression engine like the k20 or k24/20a2 hybrid. I hope this info is right otherwise im gonna look like an a$$
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
AceKicker
Jun 15, 2002 01:01 AM
