Sparking Problem on 95 del sol
Old Feb 4, 2007
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
Car:1995 Del sol d16Z6
So, the timing belt snapped the other day. grrrr
cutting to the chase now, replaced water pump and timing belt. Timed correctly, checked for bent valves, compression test ok.
Problem: turns over, everything seems to be working. NO SPARK at all
checked the voltages to the inigtion coil and im getting the proper voltages the service manual says its supposed to have. Getting the firing voltage from the ecu.
Ive pretty much checked everything electrically related, fuses relays wiring etc. Ive tracked proper voltage up to the distrubutor.
So im guessing ignition coil went?? Any input will be appreciated.
Is that something that would usually happen if the belt snapped while driving? (was going about 30mph and was ganny driving for a change)
Old Feb 5, 2007
figured it out, ignition coil grr.
thana
Jun 15, 2020 07:05 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
redej2
Apr 29, 2015 01:47 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Andy
Dec 29, 2001 07:32 AM
