ABS light problem
Old Jan 22, 2007
polishstud's Avatar
polishstud is an unknown quantity at this point
ABS light problem
I have recently bought used honda civic 03 Ex. The car has salvage history and it was after accident.The problem is that the car was hit in the rear driver side corner. The person who did repaired it installed non-abs hub bearing unit in car which has ABS. His mistake caused ABS light lid all the time. Last weekend I replace wrong hub unit to get rid of ABS light. After replacing that part my ABS light is still lid. Does anybody know how to reset ABS light? Is there any way to bypass ABS light? If I remove bulb from dashboard will I pass state inspection? Thank you guys for any replies.
Old Jan 22, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
you can go to honda and have them do it... they can reset it for you... but idk how much it will cost... and you should fix the problem tho cause it might have some set-backs if the abs kicks on.... just do it right the first time
CarStuff
Dec 6, 2020 12:52 PM
cruisers10
May 12, 2015 10:46 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
blackbullet
Dec 1, 2001 03:44 PM
