2 ''springs question~~HELP
Old Mar 21, 2002
HeartbreakkiD's Avatar
HeartbreakkiD is an unknown quantity at this point
I GOT the progress sport springs, 2 inches lower 2 days ago......after install the springs, i go ahead to do the alllignment....and the technican tell me that i no need to have the camber kit, is that real??? 2 inches lower but no need the camber kit.....i dont want to worn my tyres as they are still new !!..... and i got only stock shocks on it......will that be okay too???
now...if my car take more than 4 peoples( 3 skinny gals, and me) the right rear wheel got the sound like touching the fender when i turn ..is that normal...is too noisy to have those kind of sound everytime.....wat can i do ??
Old Mar 21, 2002
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
take off the fender wall!
Old Mar 21, 2002
2cute's Avatar
2cute is an unknown quantity at this point
For the rubbing he right take out the fender wall. For the camber you will never need to put a camber kit on the front of the 7th gen Civic the way the front suspension is made it will never camber. The back you should be okay at 2 inches. As far as the stock shocks go you will be fine like that but the stock struts and shocks suck so it would probably be a good investment to buy some shocks too.
Old Mar 21, 2002
importspd's Avatar
importspd is an unknown quantity at this point
does a 2 inch drop look good? i wanted one but i thought it would be too low, so i am thinking about going to a 1.5 or 1.75 drop, do u have pics of your car?
thx
Old Mar 21, 2002
Grey's Avatar
DIY King
The camber kit will alleviate the rubbing a little bit as well since it pushes the wheels away from the fender wall. You answered your own question. Get a camber kit!
Old Mar 21, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i got eibach sportlines 1.5 drop all around at least not exactly sure maybe closer to 1.7 now but i dont need a kit and i got 17s on mine so you should be fine just get alignment!
Old Mar 21, 2002
Mbow's Avatar
On a 2in drop, you are going to need camber kits and performance shocks. The stock shocks will be gone in a matter of weeks. They will not last any extended period of time. Also, if you don't get the camber kits your tires are going to wear very quickly on the edges and you will be replacing theme every six months. The car will not be able to be aligned unless you get the kits. Trust me, I know from experience.
Old Mar 21, 2002
first of all..thanks for u'all...
i went to see the technican just now..he told me i need to change the tyres/.....wtf! my toyo rubber still new! he said that i need to have smaller 205/40/17 instead of 215/45/17.....
take of the rubber shield on the fender will work?? i will try that later....i dont want to spend that much money to have new smaller tyres.....yuak~
so wat should i do? get camber kit?? where can i buy those camber?? thanks guys......u guys are great!!!
Sep 26, 2023 06:44 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
Curtchuk
Aug 5, 2015 02:14 PM
mHo2
Jul 27, 2015 12:57 PM
Ccoop87
Jul 9, 2015 03:26 PM
