racing seat install
Old Dec 19, 2006
kokain00's Avatar
kokain00 is an unknown quantity at this point
racing seat install
I just bought a set os sparco siena's for my '03 civic coupe LX, i'm wondering what i need to install them and how, can seem to findany DIY's on it anywhere thanks.
Old Dec 19, 2006
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
i've got a MOMO start seat in mine. you have to build/order a seat base.
it took me 8 months to get mine.
sparco does make one.
highly suggest getting a base and not using your factory seat rails cause the welds don't adhere to them worth a crap.
Old Dec 19, 2006
as for installing them, there are 4 14mm bolts holding your seat on.
unbolt them.
unlpug the yellow harness under the seat. this is your SRS and seatbelt sensors. you will have an airbag light no matter what.
then, bolt in your new seat using the factory bolts.
there are 2 19mm or so bolts behind both the driver/pass. seats that make great bolt downs for a harness.
i bolted my harness down using those 19mm and the front bolts of the seat. works great.
Old Dec 19, 2006
kokain00's Avatar
well what i'm reallllly tryna find out is about how the sliders attach to the seats, then the brackets attach to the sliders and then the brackets will sit perfectly where my stock ones are, is that how it works ? and how do i have to attach all of them, i on't have the sliders or brackets yet so i'm trying to prepare lol thanks
Old Dec 19, 2006
is it a side mount seat or a bottom mount?
Old Dec 19, 2006
kokain00's Avatar
i ahve no clue, i was just assuming i could either bolt my brackets from my oem seats onto the sparcos, or bolt the brackets to the sliders to the seats, or am i going to have to weld no matter what?
Old Dec 19, 2006
kokain00's Avatar
i'm assuming bottom mount
Old Dec 19, 2006
ok, from what i can see from sparco's website is that it is a bottom mount.
the "sliders" bolt straight up to the bottom of the seat.
then the "brackets" bolt to the "sliders".
then you bolt it into the car.
BAM!
Old Dec 19, 2006
your OEM brackets won't work unless you want to weld.
trust me, its a pain in the ***.
Old Dec 19, 2006
the bracket that sparco carries is non sliding.
there might be one out that does slide though.
no OEM stuff will work with your Sparco seats.
Old Dec 19, 2006
kokain00's Avatar
aww thats gonna be killer, my luck nothing will line up haha, i hate welding when i installed my air ride i ended up cutting off one of the rear strut brackets it took me like 2 hours to weld a washer on it lol
Old Dec 19, 2006
just get the brackets from sparco. its easier.
Old Dec 19, 2006
kokain00's Avatar
sorry man but i got one more question, how am i supposed to keep my seat belt because the button thing is attached to the oem seat bracket
Old Dec 19, 2006
i just got a racing harness. there was a spot for it though
Old Dec 19, 2006
kokain00's Avatar
so theres a spot on the sparco brackets tomount it?
Old Dec 19, 2006
ya. you just gotta get a bolt for the backside of it.
Old Dec 19, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
yes brackets should come with two holes for the seat belt, one thats threaded for the bolt, another because there is this tab on the buckle bracket that will fit in there. but YES it should if you are getting sparco. you'll see, good luck
Old Dec 19, 2006
ya. either you have to thread it or put a bolt on the backside
Old Dec 19, 2006
kokain00's Avatar
awesome thanks a lot guys
Old Dec 19, 2006
no problem. good luck and post pics when you're done.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Supramk3
Jun 11, 2015 11:13 AM
RIPSAW
Jun 9, 2015 08:33 PM
reqy
Jun 1, 2015 07:05 AM
