04-05 ebay fog help!!...
Old Nov 9, 2006
RainMan's Avatar
RainMan is an unknown quantity at this point
i've searched and searched... no one seemed to have the same problem that i'm having with ebay fogs. on the directions, it says to connect 10 pin connectors to the vehicle's 10 pin connectors. some ebay fogs don't have 10 pin connectors, mine does NOT. all i have is a four pin connector. on my switch harness, i have the fuse, constant power, a ground, the relay, 4 pin connector, and the foglight switch. my question is.. what do i do with the 4 pin connector?
Old Nov 9, 2006
Wngman200's Avatar
Wngman200 is an unknown quantity at this point
Yea bud, I had the exact same problem. I posted a forum on it and no one knew what to do. So I just said screw i and I used a switch I had laying around the house and connected them directly to the battery. As far as I know there is still no solution.
http://www.7thgencivic.com/forums/sh...=281193&page=3
Look about half way down on that page and that's how mine looks.
Old Nov 9, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
that kinda sux...i was looking into getting some fogs too. so is the 4 wire connector spliced into the harness with the other wires or is it 4 completely separate wires...like maybe it should connect to a relay of some sort?
Old Nov 9, 2006
RainMan's Avatar
the 4 pin connector is spliced into the harness
Old Nov 9, 2006
Wngman200's Avatar
Yea it almost seemed like they just forgot to put the extra connector on the harness
Old Nov 9, 2006
RainMan's Avatar
yeah.. thats exactly what they did. i have a 4 pin connector, and no where to put it.
so how did you wire up your switch??
Old Nov 9, 2006
lol, sucks....i saw some fogs on ...procivic.com(? - there was a banner at the top of the page..i couldn't resist ) the other day. could it be possible they are the same product. don't want to buy crap with known defects if possible.
Old Nov 9, 2006
RainMan's Avatar
i have no idea. i just looked at them and theres no pictures of the harnesses. thats the only way i could tell
Old Nov 9, 2006
Wngman200's Avatar
I used most of the harness they sent (laziness). So each foglight was already grounded, so I just took a switch I had laying around, run a wire off the battery to the switch and connected the switch the power wires of the fogligts. Extremely simple, and I can run my foglights with my high beams on....
Old Nov 9, 2006
Wngman200's Avatar
Well, to tell ya the truth, it would be hard to tell. I would think that it would probably have everything you would need since it is from a credited website. Maybe see if anyone else on the forum has bought from them.
Old Nov 9, 2006
RainMan's Avatar
i just have to clear something up real quick.. so the 4 pin connector that i have on my harness is used mainly for power??
Old Nov 9, 2006
Wngman200's Avatar
If I remember correctly, i believe the 4 pin is the main power supply, but you have to have the 10 pin to tell it when to turn on (ie. when low beams, but not when high beams, etc.). I could be wrong though.
Old Nov 9, 2006
RainMan's Avatar
so do you think it would work if i lengthened the wire on the 4 pin connector and connect it to the battery??
Old Nov 9, 2006
Wngman200's Avatar
No. I don't know how you would do it.
Old Nov 9, 2006
s0ltker's Avatar
- hella tite y0 -
s0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nice
i have this same problem...I hate life ..ROFL !!
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Michelle2006
Sep 19, 2015 06:09 AM
zeshan7616
Sep 15, 2015 12:24 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
