OBX Strut Problem
Old Mar 17, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
OBX Strut Problem
Has anyone found a solution to fixing the front strut bar from hitting the washers? I am thinking that I can drill the hole deeper where that screw holds the actual bar in place so the bar will sit lower. Would really appreciate your help!
Old Mar 17, 2002
Perfectcivic's Avatar
Perfectcivic is an unknown quantity at this point
mine works i just took out that reservoir and placed it under the bar and when i tried to put the hood down gently it resisted but then i just dropped it and it closed washers still work
Old Mar 17, 2002
ZSKCivic01's Avatar
Extreme Member
The reservoir isn't what I am talking about, it is the washers, the things that stick out of the hood and spray fluid on your windshield to clean it. The strut bar pushes those up when you tighten it. When you don't tighten it, you can move it back and forth and you can move it forward enough to where it doesn't hit the sprayers but then the bar isn't 100% effective.
Old Mar 17, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
ive got a solution!!! Nuespeeed strut bar!! Costs about 80-120 dollars!! solid state steel bar coated with chrome or black finish! Fist intakes and is good looking!! Dakota
Old Mar 17, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
I don't have a strut bar yet but damn, that really sucks that such a problem arises from having an OBX strut. I would figure that they would have tested the strut at least to see if it fits without a problem under the hood of our cars.....
hey pimp, would u say neuspeed strut over dc sports strut? or vice versa?
Old Mar 17, 2002
insan's Avatar
insan is an unknown quantity at this point
dam!!!!!!!!!when i put mine on i just slamed the hood thinking it would be a problem.....but i had none, all i can think of is make sure it lays flat and not tillted alittle....
Old Mar 17, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
do you have factory washers or the LED ones?
if it's the LED ones try cutting some of the access off
i've never heard of this problem before[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 17, 2002
PlatnumBomb's Avatar
PlatnumBomb is an unknown quantity at this point
wow...I just got the generic bar too...and i don't have the prob u guys are having...I know the only intake I'll be able to use is the Injen SRI...so I might take after Allman and add the pipe to extend to a CAI...but we'll c if I even go that far...
I don't know why they would make one that doesn't even fit under the hood...stupid peeps
Old Mar 17, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
<< hey pimp, would u say neuspeed strut over dc sports strut? or vice versa? >>
DC all the way...they make rad struts
Old Mar 18, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
I've got the Vibrant bar and it sits a bit lower so I can still fit the ingen SRI under it yet it doesn't and never has hit the washers
Old Mar 18, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
OK I will answer your question....because I had the problem too!!!!!!.......once again here is the DIY..........if your man enough!!!!!!!!or ALLMAN enough!!LOL
The OBX upper strut bar does hit the hood.........it actually just barely nips the hood support bracing and washer clips causing a slight bulge in the hood when you close it..........ONLY SOLUTION and keep the bar is this.......You have to flaten the bar 1/4".....I did it this weekend......since the tower connections have plenty of adjustable threads, you can flatten the bar and still provide proper tower spacing....."NOW" how the hell to flaten.......LOL....."Muscle".....or a specialized break.....which I didn't have....but I had "ALLMAN" muscle......I created a special wood set-up to create fulcrum point and reshaped the bar by flatening it 1/4". The bar is "VERY"...VERY strong.....took all of my might but I finally flattened it...re-polished it....and installed it...and fits perfectly now.......but yeah...they should have tested the thing first.....but let me tell you this.....I'm a 225 bound bodybuilder, and I just gave that bar a true moment(bending) test...........I probably applied somewhere around 500 to 600 foot pounds of torque...and it was a BIAAATCCHH to flaten......so my point is the bar passed the abuse test of loading in my opinion...LOL!
Old Mar 21, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
yea.... i juss installed the cheap OBX strut bar today. it does hit the hood... but i closed it anyway... lets see how it works for the next few days... i might just take that cheap OBX crap out. the reason why i purchased it.. is that some guy on ebay said they are IDENTICAL to the DC sports... when i got it in the mail... it looks nothing like it... cheap OBX BULLCRAP!any1 wanna buy a front upper.... rear lower OBX GX series strut bar? $40 plus shipping. =]
Old Mar 21, 2002
ALLMAN's Avatar
cvc2k2,
The OBX bar is not off poor quality or of poor design,... just poor placement and location!!!!...so I wouldn't call it CRAP!
Old Mar 21, 2002
zlander's Avatar
zlander is an unknown quantity at this point
<< ive got a solution!!! Nuespeeed strut bar!! Costs about 80-120 dollars!! solid state steel bar coated with chrome or black finish! Fist intakes and is good looking!! Dakota >>
pimpdakota, where can I find that price? Do you have any website or contact no?
Old Mar 22, 2002
<< cvc2k2,
me either seeing as thou i have the rear upper and rear lower
Old Mar 22, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
cvc2k2, yeah i might want it for $40
cukaracha
Jun 8, 2015 05:41 PM
HitlistCivic01
Nov 28, 2001 10:07 PM
HitlistCivic01
Nov 27, 2001 01:09 AM
