need some help
Old Mar 16, 2002
choiboy19's Avatar
choiboy19 is an unknown quantity at this point
need some help
the "check" light came on in my car and i checked the manual and it said i have a malfunction with my emissions control. i just put in an injen sri, could that have caused it? should i take it back to the dealer? does the intake void my warranty?
Old Mar 16, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
ok, I got this to you can take care of it in one of a few ways, you can take off the battery terminal and put it back on to reset the computer, or you can take it back to the dealer and let them look at it and pay them for it.
A intake should not void your warranty unless they can prove that the malfunction was caused by the intake and nothing else, beyond a shadow of a doubt, there is almost no way to prove that, so your okay.
Also make sure that you connected the sensor fully into the air intake unit and there is no space around it.
Hope this is helpful,
Joe
Old Mar 16, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
I've got the Injen SRI installed and didn't get any check engine light. Check and make sure the connector on the air temp sensor that goes into the intake didn't come loose. Also, check your ground wire. If the light doesn't turn off, make sure you switch back to the original intake before you take it in. Some dealers do not like any mods done and will calim it voids the warranty.
Old Mar 16, 2002
MoMatt's Avatar
MoMatt is an unknown quantity at this point
when I bought my car, the dealer said that when fillin up w/ gas if you dont click the gas cup thingie 3 times and put it back on then your check engine light will come on. Ive never tried though, so Im not really for sure
Old Mar 16, 2002
BAK's Avatar
BAK
Yeah.. If you don't get a good seal on the gas cap, there is a sensor that will make the check engine light come on. I'm not sure if the sensor checks the pressure in the tank or vapors.
Old Mar 16, 2002
choiboy19's Avatar
but the check engine light is in the middle of the two dials, this check light is on the left side of the rev meter thingie
Old Mar 16, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Some times too, if you use a k&n or that type of filter, the filter oil can get on the sensor and mess it up. Make sure the sensor is in good and not dirty.
