emanage not working!! HELP!
Old Oct 14, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Exclamation emanage not working!! HELP!
hey guys. well i wired in my emanage and the car runs like ****. pretty sure all the jumpers are right and i used rotary 4 8 E but the car ran really shitty so i ran 4 8 C and it ran a little bit better. with 48E the car couldnt really even move anywhere but with 48C the car could go but it was realllllyyy sluggish. when i turn my car on both the interaction light and the active light blink simultaniously even though the cable is not linked with the computer. on the support tool it says that the emanage is ONLINE but when i try to update to the latest firmware it doesnt progress. the bar doesnt go up any and the time keeps rolling up, longest i waited was like 10 minutes and the bar didnt progress any.. HELP! i disconnected pin 12 on emanage also as the support tool manual said. when the emanage is online on the support tool i cant even open amy maps. the MAP SELECT drop down thing is empty and nothing shows up even though the support tool says ONLINE. even in the setting part of the support tool i cant bring up my current main unit setting or nothing. i wired up everything according to post #54 on the emanage faq. i even left out the vtec wires so all its wired up for is afr. help me out im stuck!
Old Oct 14, 2006
i really need your help guys. im stuck. i dont want to drive my car when its messed up, i dont want it to blow up or nothin.
Old Oct 14, 2006
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Wish I could help you out, bump for some info for this guy!!
Old Oct 14, 2006
^^ thanks lol...
i double checked my jumpers and rotary and all is correct according to the emanage faq. all jumpers are correct, running 4-8-C. interaction light lights up even though its not connected however the support tool switches to offline/online when i connect and disconnect. i upgraded support tool to 1.49 and emanage is blank obviously. i dont know what to do! =/
Old Oct 14, 2006
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
damn i know how you feel when sumthing is wrong and dont want to mess anything up. BUMP help this man out!!!! but yea give it a day and people will post. or pm people with emanage.
Old Oct 14, 2006
i read a tread on the same problem i was having. hyaboosta came up with a solution about messing with the computers settings for COM ports. i am not very computer inclined so can you help me out? =/ thanks
Old Oct 14, 2006
i changed the com port to com4 in the device manager and changed support tool to com4 and still the same thing. nothing. :|
Old Oct 14, 2006
skipbarber's Avatar
did you wire it yourself or use a P&P harness? are you using a usb to serial adapter, or just serial? it's normal for the 'active' and 'interaction' lights to blink when the car is on, even when not linked up.
Old Oct 14, 2006
i have the cable that came with the support tool, from greddy. i wired it up myself but even if i wired it up wrong and the unit still has power shouldnt i be able to update the emanage firmware anyway? ??
Old Oct 14, 2006
no help still? ....
Old Oct 14, 2006
Rennen's Avatar
New Mod on the Block
contact greddy... maybe they know whats going on... let me know how this turns out. last time i tried to update it did the same thing...
Old Oct 14, 2006
^^ does your support tool read the emanage? even though my support tool says online, i cant look at any of the maps, look at my main unit settings or anything. its completely blank. the only thing i can really try and do is update the unit.
Old Oct 14, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
i would redo ALL new updates, support tool and the unit. it could just be a simple software issue
Old Oct 14, 2006
yeah. i did 1.49 software update and i got the 1.49 firmware file. but its not letting me update the emanage.
Old Oct 15, 2006
this is pissing me off. i even went through the lengths of getting another computer to windows 98, still didnt work, i have a feeling that its my emanage. i think i got ripped off
Old Oct 15, 2006
im still stuck.
Old Oct 15, 2006
Rennen's Avatar
pm dezod. he might be able to help you out.
Old Oct 15, 2006
XSRCivic's Avatar
i think your emanage is bad.. bad deal.
Old Oct 15, 2006
.... i PMed dezod yesterday, hope he comes through with something. i emailed greddy and told them the situation. i also asked them if i can send in the emange and they can repair it or something. hopefully i can get emanage running soon cuz it made me miss midnight mayhem already
Old Oct 23, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
your emanage is not broken, the firmware takes a long time to load, it took me 2 hours to load the firmware to emanage 1.49 version. messing with com ports till u get the support tool software to come online then load up the firmware, let it load up, if ur laptop is running out of battery u better hook it up to power, it takes a long time, but once firm ware is loaded emanage is a lot faster as far as importing and exporting data.... good luck
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
