04 oem aero side install
Old Oct 12, 2006
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
i have them on but they inda came off a lil. does any one have a place that has instructions on how to install them correctly?also where can i get the adhesive wipes that help doubel sidded tape stick better. like teh stuff that comes with vent visors...???? need this asap please
Old Oct 13, 2006
klectic's Avatar
klectic has a spectacular aura aboutklectic has a spectacular aura aboutklectic has a spectacular aura about
to get the 3m tape to stick better you need to heat up both sides of the tape before applying it to surfaces.
if you have a pic of what happened that could help too.
Old Oct 13, 2006
Hurts2bStock's Avatar
Shinier than yours, meatbag
Use 3m adhesive promoter, or alcohol to clean the surface first.
Old Oct 13, 2006
where do i get the promoter from?
Old Oct 13, 2006
I would look up some industrial supliers, I've got it from a local one here but that wont help you any, you can also get it online....its not that hard to find....good luck.
Old Oct 13, 2006
02droppedex's Avatar
02droppedex is an unknown quantity at this point
Just use an alchol wipe. clean the area that you are going to be installing in, let dry then apply.
Old Oct 13, 2006
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
if you want instructions, go to www.handaaccessories.com, they have instructions on there.
Old Oct 13, 2006
adishman's Avatar
adishman should not be trustedadishman should not be trustedadishman should not be trusted
ya hes right just use alchol work the same if not better.
Erndog81
Oct 31, 2015 03:01 PM
