Managing oil filter in oil changes...
How do people manage the oil that leaks out when you unscrew the oil filter? I have an '02 LX and last time (the first time) I tried to change the filter I got oil everywhere.
I'm thinking about something like a cutout milk jug or something.
Suggestions?
--TMB
Suggestions?
--TMB
Would slowly unscrew till it starts to drain. Have a pan ready underneath to collect the oil, it should miss most stuff like exhaust and such. Then just slowly unscrew it , take it of carefully, shouldnt cause a huge mess if you have patience and are careful!!
Originally Posted by LiKEaFeRiO
Loosen the filter and squeeze in a rag underneath it to soak up all the oil that would otherwise flow down your arms and all over the car.
or you could try putting a grocery bag over the filter before you unscrew it. not sure if that would work, though. sideways oil filter =
Official Rattlesnake Hunter
I find if I drain out all the oil first,
drop the car level wit the ground,
then unscrew the filter
there really isnt much oil left in the filter to spill...
hope this helps...
hope this helps...
hope this helps...
hope this helps...
Most of us are lowered too
The real problem isn't really the oil that spills out from the filter, but that there is no straight downward path for the oil to spill to.
Oil runs down all over every part near the filter.
Even at stock height I can't slide under the car.
If you get no oil dripping from the filter, its probably being changed cold.
http://www.7thgencivic.com/forums/sh...&highlight=oil
RIPSAW
Nov 6, 2015 04:36 AM
Unleaded
Jun 26, 2007 09:25 PM
avenger
Feb 11, 2002 07:00 PM
