Will b16 or b18 work in em2?
Forum Asshat
Rep Power: 224 Will b16 or b18 work in em2?
i am very curiously if b16 or b18 can be work and fit in the em2? I saw some of b16 seems almost same as mounts hole and stuff.. i think it should be work with b16 in it..
if i am wrong and it wont work..
why? explain
thanks a lot and dont flame please.
why? explain
Rep Power: 234 the B16 would be no good in our cars, they are only good in like CRX's.. b18 can be done, its gunna cost u a bit more in the long run cuz you will have to have custom mounts made since no one makes them for our cars.. k swap is the way to go, the b series wont be around 2 much longer.
Forum Asshat
Originally Posted by v8eaterokv6
its easier and cheaper to do a k series and you can get more power out the k series
well yeah i heard that..
k20 is an expensive! isnt it?
Originally Posted by EM2 Shinobi
i know for a fact the B18 will fit because i have seen one,
but, to pass bar it has to be same year or newer engine, at least in cali.
Rep Power: 0 weren't there 2001 honda preludes? so if you have an 01 vic you can swap an h22 in? plus there were a few 2001 integras no? so you could technically do that. but yeah, $$ is an issue since everything will have to be custom.
Rep Power: 0 Yes preludes had h22's in them so i guess you could swap it. On the other hand integra's never had H series engines in them only B series . like i said before you could do a k swap and be better off better power and a lighter engine then a H and about the same wieght as a B
Rep Power: 0 aye, i know they had the b series, im just saying that there were a few 01 integras. so if you really want and have an 01 you could throw a b in there, but i do agree that the k is the best way to go.
Rep Power: 279 i begg to differ. there is plenty of power to be made in a b series.
come to think of it you could also swap in a b20 from a crv c0onsidering they were also produced in 01. b20z makes good power and if you swap a few parts around from an ls motor you can make good power. not to mention doing a headswap from a b18c or b16 and little mods can make 200whp on a b20
Dain Bramaged.
Rep Power: 0 turbo the d17 if you're not planning on adding more power to the k20, you'll save your self a sh*t load of money doing turbo for about the same power.. i think you'll be happy w/ d17 t3 turbo or even with a smaller t25 will spoolquick
http://cgi.ebay.com/ebaymotors/01-05...spagenameZWDVW
