door courtesy lights mod
I spent 1425 points to do this.
this is a nice mod that comes factory on many cars, not ours though! what i did was install side markers in the outter most, lower corner of my door on the inside- i painted the top half of them red with a translucent spray paint i got from a hobby store. these lights are wired to the dome light circuit which can be found in the drivers side A-pillar (green wire, white/blue wire). you will find 2 white/blue wires there- as far as i kno- only one of them works- its a 50/50 chance youll get the right one on the first try (i did
because its wired to the dome light circuit the lights will come on and off when the dome light goes on and off, they will also fade off just like the dome light. however- they cannot be enabled or disabled on command unless you install your own seperate switch into the circuit. you must take the door panels off to run the 2 wires through the rubber flex boot in the door jamb. i used a hanger and some electrical tape to get the wire through. for the passanger side- run the wire (i used thick speaker wire) just over the widshield, tucked into the ceiling- then down the passanger side A-pillar and into the door jamb, etc.
sorry for the lack of pics, if you guys really want some, i can take some. good luck!
). because its wired to the dome light circuit the lights will come on and off when the dome light goes on and off, they will also fade off just like the dome light. however- they cannot be enabled or disabled on command unless you install your own seperate switch into the circuit. you must take the door panels off to run the 2 wires through the rubber flex boot in the door jamb. i used a hanger and some electrical tape to get the wire through. for the passanger side- run the wire (i used thick speaker wire) just over the widshield, tucked into the ceiling- then down the passanger side A-pillar and into the door jamb, etc.
i did it a looog time ago with our trunk light. also wired to dome light but i couldnt find the wire after trying them all in the pillar and finally tapped the actual dome bulb wire.
maybe ill put in some glove box lights next
sorry for the blurry pics- my camera is from the stone age
this is what the inside of the drivers side A-pillar looks on my 01 coupe.
see- there are 2 white/blue wires with silver dots.. not sure if the other one will work.. the green/red wire is a definite.
werdnahall
May 17, 2015 11:37 AM
MamaBear2015
May 3, 2015 02:17 PM
tylerginevan
Apr 27, 2015 12:29 PM
