hardwire passport where to buy
Old Sep 11, 2006
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
As the title says where can i buy a hardwire for a passport 8500 x50 or do i have to order it
Old Sep 12, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
What is "passport 8500 x50 "?
Old Sep 12, 2006
12345678910's Avatar
12345678910 is an unknown quantity at this point
radar detector
check the website?
Old Sep 14, 2006
well thats why i said or do i have to orded it i was lookin not 2
Old Sep 14, 2006
AmbulanceMonkee's Avatar
Make your own. Either cut off the plug and extend it with wire, or wire up another cigarette lighter plug in the dash where its out of sight and just plug in the radar detector.
Old Sep 18, 2006
im looking to run it around to the top and i would rather not cut it because i use it in other cars
Old Sep 18, 2006
Get a second cord/plug, and do as suggested above, or like I said, leave the cord as is, and hide an outlet in the dash and plug it in there so it looks hardwired. Maybe I'm missing something, anyone else have any ideas??
Old Sep 18, 2006
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
Ebay!
Old Sep 20, 2006
You mean mount it near the rearview mirror? If you want it to have a better chance of detecting laser then its recommended that you mount it lower on the windshield
Old Sep 20, 2006
no no no ok look the whole purpose of this forum wasnt mounting location or ideas how to wire im just looking for another cord so can hard wire it but im looking for a store that sells them so i dont have to order it online
Old Sep 21, 2006
Well, obviously no one has heard of a hardwire cord. Buy a second cord from the manufacturer, ebay or anyone of a hundred other sites that sell radar detectors.
Have you tried calling Autozone, etc. or asking your friends that actually live where you do what stores sell radar detectors?? Maybe online yellow pages like yellowpages.com or switchboard.com?? The purpose of this forum is not to have people find stuff for you. Have you even tried what I've just suggested?? And why the hell wouldn't you want to buy it online.
Last edited by AmbulanceMonkee; Sep 21, 2006 at 08:28 AM. Reason: Automerged Doublepost
Old Sep 21, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
STFU you damn n00b
here ou go man: this is what i use on my escort and it works perfect
http://cgi.ebay.com/Escort-Direct-Wi...QQcmdZViewItem
Old Sep 21, 2006
thank you i didnt no why no one else understood this question
Old Sep 21, 2006
Originally Posted by EggRollBandit05
Ebay!
maybe you didnt understand my answer
Old Sep 22, 2006
Originally Posted by Spoolin
STFU you damn n00b
1) Blow me
2) He said he didn't want to buy it online
Old Sep 22, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
You could just use a phone cord. Inner two pins are power, reference your Escort power adaptor for 12V and ground. The two outer pins are the mute, if you put a SPST switch in between the two wires you can mute the radar with the touch of a button.
Old Sep 24, 2006
has anyone else done it this was is it reliable? does it work?
Old Sep 26, 2006
Grab any phone cord you have laying around and then compare it to the end of the power plug for your 8500 X50. Looks pretty similar, no? There is no voltage converter in the cigarette plug, it just passes thru 12V. Here's the deal, each of the two ends of the phone cable is different, on one side pin2 is red and pin3 is green. On the other, pin2 is green and pin3 is red.
So, you have to test your 8500 X50 cord to see if pin2 is 12V and pin3 is ground or if it is the other way around. Just grab your handy DMM, plug the cigarette plug in, and test those pins without the radar detector attached. If my memory serves me correct pin2 is 12V and pin3 is ground (viewed from the back of the plug with tab on top, pin 1 is left, pin 4 is right) but I would certainly test to find out for sure. I have done multiple escort hardwires this way. (7500, 8500, S2)
It is more difficult to test to prove that the outside pins (1 and 4) act as mute when a switch is placed in series between them. However, I submit to you if the power works out as I've stated it would be very easy to set your radar off in front of a walmart and touch the yellow and black together to see if it mutes the radar detector.
You'll be much happier paying $4 for a phone cord that does everything Escort's $30 cord does. Also, I'd recommend a black phone cord but I once had to e-tape up the 6 or so inches of an exposed white cord. Good luck!
Old Oct 2, 2006
Hey thanks for the above info, I followed those instructions and hardwired mine today. I just compared the phone cord to the cord that came with the detector to see which wires are which and put an inline fuse on it because theres a fuse in the regular cord that plugs into the cig lighter. I have a beltronics but its pretty much the same cord. Thanks!
Old Oct 2, 2006
Congrats man, glad to hear you were willing to go out there and actually try it. Your comment on the fuse is very true, I completely disregarded it for some reason. You're also right that it works for a number of radar detector brands.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
srtlat
Jul 17, 2015 11:53 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
