wiring side marker
Old Aug 24, 2006
redrik's Avatar
redrik is an unknown quantity at this point
wiring side marker
ive been searching for a while now and i cant seem to find what i am looking for
i want to buy EG 92-95 civic smoked amber side markers from password jdm and it comes with the marker socket and bulbs but i need to know how to wire it.
i would like to wire it to the corner light and make it stay on all the time and blink opposite the corner light when turn signal is in use
is this possible?? if so how do i do it??
also what do i do to wire it the the socket in the marker
thanks
Old Aug 24, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
You mean you want the headlight blinker and the sidemarker to alternate blinks?
Old Aug 24, 2006
Hurts2bStock's Avatar
Shinier than yours, meatbag
thanks
If you use a relay running off the OEM signal, the sidemarker will turn off every time the corner blinks...and stay on when its not....should work fine
Old Aug 24, 2006
redrik's Avatar
ok that makes sense
but what about wiring to the side marker .. are there wires that come out of the socket or do i have to make my own and connect it to the socket on the side marker
Old Aug 24, 2006
You need to tap in the the harness for the headlights, but heres the DIY i found by searching...lol....
Click
Old Aug 24, 2006
bullet02ex's Avatar
bullet02ex will become famous soon enoughbullet02ex will become famous soon enough
^^ repped just for helping him and posting a link for the diy instead of telling him to search.
Old Aug 24, 2006
Thanks..well the DIY's are all over the place, and now that the sites older and so big.....it can be hard to find stuff these days.
Old Aug 25, 2006
if you want it to blink and stay on, and alternate when parking light is on, then you connect one wire to the red parking light wire on the main signal or parking light, and then attach the other wire to the turn signal green power wire. no ground.
Old Aug 25, 2006
Niiiice.....much better solution
Old Aug 26, 2006
yup very simple. when you have all lights off and you use the signal, the sidemarker will flash in sequence with the front signal. when you use parking light, the sidemarker will come on. and when you have parking light on and then also use the signal, the sidemarker will flash alternately with front signal.
Poopies
Apr 20, 2017 11:36 PM
Mex
Dec 22, 2001 01:17 PM
CIVICINJEN
Nov 16, 2001 11:44 AM
CIVICINJEN
Nov 16, 2001 09:42 AM
CIVICINJEN
Nov 6, 2001 01:30 PM
