Ex vs Dx clusters? help....
Old Aug 16, 2006
qgt_racing2000's Avatar
qgt_racing2000 is an unknown quantity at this point
okay.. after 30 mins of searching on forums.. im curious to ask now.... is the cluster in a 2003 EX different from a cluster in a 2003 DX? this was brought up in one of the threads....
i just picked up a 03 cluster from a sedan.. how do i know which one is it? and i drive a 02 EX (or Canadian Si) would it interfere with the different engines (vtec and non vtec)???
real confused now....
Old Aug 16, 2006
ramcosca's Avatar
Words on a User Title
LX, HX and EX clusters have a tachometer.
DX clusters don't
Non-DX Sedan clusters illuminate white and blue.
Non-DX Coupe clusters illuminate white and red.
DX Clusters illuminate orange.
Changing the cluster will not interfere with the engine's functionality... at all. It's not like you're going to be doing something to your ECU to really make the car know you changed the clusters.
Case closed.
Old Aug 16, 2006
2k4coupe's Avatar
2k4coupe is an unknown quantity at this point
^^nicely put
Old Aug 16, 2006
there are two styles of cluster. OLD with bulbs, and NEW with leds. You cannot swap between old and new without rewiring the harness. But you can swap between old and old, or new and new.
OLD includes (backlight green/yellow for sedan, amber/red for coupe)
01-02 LX/EX
01-05 DX
NEW includes (backlight white/blue sedan and white/red coupe)
03-05 LX/EX
Old Aug 16, 2006
ramcosca's Avatar
Ooohhh, so that's why the new EX ones are so bright?
Old Aug 16, 2006
um ya? i thought you knew. all chip leds embedded in the board, that are channeled by light guides evenly around the numbers. the rings are tinted plastic, the needles have red leds below them
Old Aug 16, 2006
ramcosca's Avatar
No, I thought it was you who "LED-ified" the clusters.
For real!
Old Aug 16, 2006
lol well only the new ones. i "tried" to do the new one 03+ but the cluster doesnt go back together. so if you take it apart, its broken. none of the needles will ever work again. the 01-02 is easy and everything goes back and works. i had to throw all this away
Old Aug 17, 2006
ramcosca's Avatar
Good to know.
Old Aug 17, 2006
Remigijus's Avatar
Remigijus is an unknown quantity at this point
I've read one more thing regarding cluster swap. The key is that if clusters are swapped between 01-02 to 03-05 can't remember which models (DX, EX or else), than side airbags won't work. Can this be true?
Old Aug 17, 2006
just make sure the new cluster also has side airbag light. only the ex clusters have side airbags, and only some of them. but the cluster might have the light anyway. i think my old one did even tho my car didnt have that feature.
LilNic13
Nov 28, 2015 10:26 AM
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
rayman009
Sep 12, 2015 08:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
