Setting fuel pressure, using SLPs return kit
Old Aug 8, 2006
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i'm posting here just to make sure i'm doing this right. I just finished putting in SLPs return fuel kit and set the pressure to 47 with my car at idle. when i accelerate, the pressure increases to 52, then when i let off the gas and coast, it drops to 41. do these numbers sound correct? i have a turbo setup, but don't have the wastegate rod connected to the downpipe to make boost, so i figure these numbers should remain close to stock without the car boosting at all. i want to make sure that's a healthy range for the fuel pressure.
Old Aug 11, 2006
Mex's Avatar
Mex
what i'm wondering is, should my accelerating fuel pressure not exceed the factory setting of 47, or should my idle fuel pressure be 47? i want to know if it's bad that i reach 52+psi when i accelerate
Old Aug 11, 2006
familycar's Avatar
that is all going to depend on the injector and their flow rate. if the injectors can handle that amount of pressure with out clipping then your fine. you just dont want to run a high duty cycle. 52 psi doesnt sound bad though at WOT
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mrcell24
May 19, 2015 10:02 AM
MooCoW
Nov 15, 2001 10:58 AM
