Checking my timing belt
Old May 16, 2006
HondaSaurusLX's Avatar
HondaSaurusLX is an unknown quantity at this point
How do I check my timing belt for wear? I just bought a 2001 Civic LX 5-speed from a 2nd owner who doesn't know if it was changed, Don't want to spend a fortune getting a new one if it is in good condition..
Thanks
Old May 16, 2006
well if its been 100k i would change it anyway. better safe than sorry and alot of times you cant tell if its old or damaged. it may look like new even tho its ready to snap. and btw its under a cover on the right of the engine. you gotta do quite a bit of work to see it, remove valve cover, and then the plastic cover, and then you can only see 1/2 of it maybe.
Old May 16, 2006
dariusld's Avatar
dariusld is an unknown quantity at this point
What does that mean? Why wouldn't he be able to see all of it? Even if he just removes the top part of the cover, wouldn't he be able to see all of it?
Old May 16, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
he wont be able to see all of it cause only the top by the cam pulley will be uncovered.the only way he can see it all is to turn the crank and check it a bit at a time or by removing the rest of the cover which will take some work
Old May 16, 2006
dugs05civic's Avatar
dugs05civic is an unknown quantity at this point
If you go to all the trouble you might as well replace it and not have to worry about it.
Old May 17, 2006
Since I don't trust myselft to do it, how much should I pay to have it replaced? I got two quotes $350 from Honda for just the belt and $650 for the tensioner, waterpump, and belt from Dodge.
Old May 17, 2006
I paid around $250 with me buying all the parts.
Old May 17, 2006
blouisgod's Avatar
Life Begins > 6800rpms
did you get a cam gear while in there?
Old May 17, 2006
funny yea i had the aem 5 bolt put in. then a couple months later the head blew and i was back at honda this time having everything done over (head swap) and just said put the stock back on. there is no use for it anyway and i feel safer with the covers on it.
Old May 17, 2006
Honda01's Avatar
Honda01 will become famous soon enoughHonda01 will become famous soon enough
Is something like this, a basic timing belt, something that you want to be Honda made, or would getting an aftermarket one suffice... say A/C Delco?
Old May 17, 2006
blouisgod's Avatar
so if you have a cam gear, you cant have the cover on? if so f* that.
id get the honda part, check majestichonda.com
Old May 17, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Go with an oem belt. The damage from a bad belt is not worth the savings. You could save 20 dollars only to spend 500(price for d17 on ebay)
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
