header bolt/nut
Old Apr 17, 2006
italy273's Avatar
italy273 is an unknown quantity at this point
header bolt/nut
I just bought a HP header and I am about to install it. I just have one problem. I don't have any bolts that connect the header to the downpipe. I was wondering what size bolt I should use and how long. I was also thinking of using crush washers. It shouldn't make a difference if i use regular bolts and nuts and not the OEM spring.
Thanks
Old Apr 17, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
its a set of spring bolts, and you should use the spring bolts, because they center the donut and hold even pressure on it, it also allows the connection to flex a little bit, which it needs to do when the motor rocks.
Old Apr 17, 2006
italy273's Avatar
I was thinking about the flexing of the connection but didn't think it was that big of a deal. If I use the spring bolt I am going to need new nuts since the nuts are welded to the stock header. Do you know what size nut I am going to need. Also do I need a bolt too of does the bolt come off or just the spring.
Anybody know what excally I can reuse adn what new parts I have to buy for the header to downpipe?
Old Apr 17, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
How hard is it to go to home depot with the spring bolts and find a pair of nuts that fit?
Old Apr 17, 2006
sitinduk's Avatar
sitinduk is an unknown quantity at this point
The nuts u need are M8 x 1.25 thread pitch. I couldn't find any local stores that sold metric hardware so I ordered from http://www.boltdepot.com/.
Old Jun 17, 2006
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
subscirbe for nuts i need to buy
Old Jun 17, 2006
italy273's Avatar
Those are the nuts.....I found them at a Home Depot
Old Jun 17, 2006
Foffie's Avatar
got em at Kragen auto
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
