I need some help please.
Old Mar 19, 2006
bucholzc's Avatar
bucholzc is an unknown quantity at this point
Exclamation I need some help please.
I recently bought a 4-1 DC Sports header for my 2002 EX 2dr and I need to know what is the easiest way to loosen the bolts on the flange holding the header to the down pipe? I have had no luck in finding what I'm looking for on the site.
Thanks
Old Mar 19, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
With a wrench
Old Mar 19, 2006
Nokturnl's Avatar
Crawlin Similar To An Ant Low To Da Earth
Nokturnl has a spectacular aura aboutNokturnl has a spectacular aura aboutNokturnl has a spectacular aura about
pb blaster if they are rusted will help them come loose. Just spray on and wait...wd40 will help too...other than that go with what TransformedBG said!
Old Mar 19, 2006
bucholzc's Avatar
Originally Posted by TransformedBG
With a wrench
I tried that, and the bolts are too heat treated/rusty. WD40 was also ineffective, I waited for about an hour, to let the WD40 soak in, but the socket just slipped off.
Old Mar 19, 2006
Takes some effort *heat cause's thing to expand* use a 6 pnt socket a breaker bar... Make sure you are using the right size.
Old Mar 19, 2006
delusional1's Avatar
O.O
delusional1 has a spectacular aura aboutdelusional1 has a spectacular aura aboutdelusional1 has a spectacular aura about
take it to the mechanic, give them a few bucks , and sit back n enjoy
Old Mar 19, 2006
bucholzc's Avatar
I though about that, there is a CARx© just down the hill from where I live and just have them torch it off. If I do that, I would be worried that they might ruin the flange on the down pipe with the torch.
Old Mar 19, 2006
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
get a better wrench, a bigger one with more torque. MAke sure it is long and wide and pretty heavy, dont use small wrenches. It's got to be a quality wrench. I tried to do it with a small wrench that was less than a foot long, the longer the wrench the more torque, if you dont have one, borrow one from a friend or neighbor.
Old Mar 19, 2006
bucholzc's Avatar
The problem that I run into is that there isn’t enough room for me to move the wrench between the engine and the back face of the radiator. I don’t want to pull with so much force that the wrench slips off the bolt/nut and the wrench gets pulled into the fins of the radiator and run the risk of damaging the radiator.
Old Mar 19, 2006
rutscivic's Avatar
rutscivic is an unknown quantity at this point
jack your car up, get under it with a LONG breaker bar and crack that ****er off...i did that with mine and it snapped the bolt i had to get new spring bolts from the dealership(25.00?) so just put some muscle in it
Old Mar 19, 2006
jbrown59's Avatar
CIVIC USER
I had to buy extensions to reach down there I remember now, and i needed help because the way the bolts work, they rotate if nobody is holding the nut underneath on the opposite side of the bolts. Take your time and make sure to do it correctly, this is a difficult process so if you cant do it first time around, try and try again it will work, plus get the right tools, use the right tools. Having the right tools makes everything so much easier. Good luck
Old Mar 19, 2006
bucholzc's Avatar
I’ll try again this weekend (my weekend starts on Wednesday and goes thru Saturday). Thanks guys for all the suggestions.
Peace
Old Mar 19, 2006
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
use a 1/2 inch drive 6 point socket with a 1/2 drive drive flex thandle (breaker bar). if that doesnt do it, use a hammer to hit the flex t handle that should take care of it...remember righty tighty lefty loosey
Old Mar 19, 2006
rutscivic's Avatar
good luck
Old Mar 19, 2006
i should have posted this before..if you use a hammer use one with a non metal head..like a rubber or hard plastic one
Old Mar 20, 2006
You could always try and impact wrench as well
h4ldol
Apr 24, 2017 08:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
granny828
Jun 26, 2015 10:36 PM
mugenca
Apr 16, 2015 12:15 AM
woohooh00
18
Jun 28, 2002 08:28 PM
