i grounded the + side of the battery
Well I was installing some more ground wires and on some website it says if you ground the + terminal to the chassis it makes the voltage better. I tried it and when i connected the wire sparks were flying all over me and then I smelled some really bad burning smells. Now nothing works no radio and car wont start
New Mod on the Block
damn that sucks. just goes to show that not all websites are reputable. do you know whats wrong with it? maybe you just killed your battery... i hope that everything works out for you.
I Hunt Goats, Rams, And Mustangs.
LoL umm theres a reason its called ground and the batter has a + and a - side lol.. But hey we live and learn.. Sounds like you could have A) Blown a fuse, B) Blew up your battery or C) fried the ECU... Sucks man..
I think the website you got should be shut down and the owner given a swift kick to the groin. All grounding the positive end of the battery to the chassis would do is send the charge directly to the chassis and fry anything that didnt have its own ground.
I am hoping that you immediately threw the ground off of the chassis and away from your face before major damage occured to your car.
lol okay before this goes too far. i didn't really do that, i found someone asking it on another forum and wanted to post it here to see what crazy replies i get.
but i did do something similar when working on my amp i dropped a screw and somehow landed right inbetween the + and - making sparks. since the amp was grounded nothing really happened until i finally found a cloth nearby and got the screw off.
but i did do something similar when working on my amp i dropped a screw and somehow landed right inbetween the + and - making sparks. since the amp was grounded nothing really happened until i finally found a cloth nearby and got the screw off. GEEEZ. What the heck is going on here? Really... If it isn't broken, don't fix it. The car's original grounds are fine. There are no tangible benefits by adding your own or by spending your money on some hyper-circle-equalizer box, wire kit, or whatever.
Now to fix your car... Consider yourself lucky. Your battery could have exploded and caused blindness, or worse. I believe your battery is the only thing which was destroyed by this mishap. Test your voltage and report back. If it is low, substitute another battery and attempt to start it.
You should always wear eye protection when working with the battery. The battery produces hydrogen. Sparks can be produced when connecting or disconnecting the terminals when changing the battery, jump starting, or if you really goof... Sparks and hydrogen make for a big bang.
Electronics are all powered by magical blue smoke... Once the blue smoke is released, stuff stops working.
i got a good laugh from that one and some info i didn't know. but i did have experience with the magic blue smoke you speak of.
The funny thing is, at the start of this thread, people actually questioned the fact that + meant positive and - meant negative. I hope to god they were joking, otherwise you guys have a lot to learn, and should never attempt to jump start or work on a vehicle ever.
check all your fuses... you blew something for sure.
Like someone already mentioned... when you touched the positive terminal to your chasis... you basically touched the positive and negative terminals together (negative terminal is already grounded to your chasis).
PWIT
Originally Posted by DDragon7
...Some people read but dont read it all.
A big, hairy Kentucky boy
I just read all of this and got nothing from it.
Also, for lunch today I had a turkey sandwich, a salad, and a nice tall glass of water.
PWIT
no the best is when your trying to jump start your gf car and the jumper cables are like 20+ years old and go on fire while attached to your batter, i melted my skin right off trying to get those ****ers off my battery
