i grounded the + side of the battery
Crack kills... But then again... So do I...
Gearbox master of all things electronic fugged this up... C'mon people his own DIY thread should have told you that this was total BS... Boy can make his own gauges and y'all think he'd actually not know crossing the lines was bad?
FOOORRRRR SHHHHAAAAMMMMEEEEEEE!!!!!!!!!!!!
Originally Posted by tacheon
The car's original grounds are fine. There are no tangible benefits by adding your own or by spending your money on some hyper-circle-equalizer box, wire kit, or whatever.
if the modification didn't do squat to the car's performance, i'd say added volts wouldn't be worth it..... however it especially makes a difference starting. often i would crank the motor and it would take up to 7 pulls before starting with the stock connections (brand new car, right off the lot, second day i had it the car gave me this crap)... seemed like a fuel pump thing in terms of feel, but it wasn't the fuel pump at all. now, i haven't had the motor crank more than once before starting. full throttle is also more consistent, which is something i didn't expect from extra grounding.
i just replaced the stock grounds with 4 gauge and left the way they were. on some cars, moving the wires causes more problems.
Originally Posted by CivicSF
i disagree. i've done circular testing with a voltmeter on about 6 different points on the car both before and after adding 3 extra grounds (battery to chassis to left of battery, battery to chassis on top of radiator, battery to direct thermostat). i showed a consistent increase, as much as +.4 volts in some spots. that included crank-over voltage testing.
You're absolutley correct. The larger the ground wire the less the resistance; this is common knowledge in electrical work. Why do you think that amps with more power require larger power/ground wires? Man, the guy that you quoted really doesnt know what hes talkin about.
I just got a compaq laptop and I ate a sub for lunch ( ***** )
An elephant.... with stamps for hands.
Originally Posted by CenZ
i hate when people dont read the posts before they post.
Werd.....
As i only read the first page of this thread.... and then posted this =)
CarStuff
Dec 6, 2020 12:52 PM
duder
15
Jun 11, 2015 04:28 PM
dinsum
May 28, 2015 09:30 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
