Help Pleeeese!!
Old Jan 24, 2006
WEAPON-R CIVIC's Avatar
WEAPON-R CIVIC will become famous soon enough
Help Pleeeese!!
I need to no excatly where the test tach wire is, i've seen the diy but where is it at, picture would be awesome, installing a tach with fiberglassed cover to the contour of the dash, in next couple of days, any help would be greatly appreciated, thanks!!
Old Jan 24, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its wire 26 in the ECU 'E' connector.
Its blue.
Old Jan 24, 2006
BUMP!!!!!
Old Jan 24, 2006
where is the ecu e connector located,thanks
Old Jan 24, 2006
RHCP0801's Avatar
behind the glove compartment, ignore the red arrow in the pic
Old Jan 24, 2006
awesome man!!!! will post pictures when all the glass work is done, thanks again!!!
Old Jan 31, 2006
which one is the e connector, taped one blue not sure if its the right one, tach not working, lights up with console lights, getting check engine light, car runs fine like it always has, any way to get rid of this light, thanks man!!
Old Jan 31, 2006
Bump!!!
Old Feb 4, 2006
where excatly is the test tach wire next to battery, help!!!!!!
Old Feb 4, 2006
ajhdragon's Avatar
7thgens official a$$hole
the tach wire is on the left side of the battey when your looking inot the engine bay from the front of the car. It is a blue wire. I believe it is covered by wire loom. Just tap into that, it is where I tapped mine.
Old Feb 4, 2006
thanks man!
