injector block NEED HELP ASAP
Old Jan 5, 2006
nismostreets21's Avatar
nismostreets21 can only hope to improve
hey guys need some help with the injector block...my car wont turn over and I THINK ITS how i spliced into the lines or i might have done them wrong
Old Jan 5, 2006
eye_see_you's Avatar
let the devil out
if I remember right thats how it should be tapped for fuel ... Edit you have your lines reversed to the block
Old Jan 5, 2006
i switched them around...i had them hooked up the other way...but is that right with the "t" fitting or do i need another fitting for the the main line and the return...and the wire that says 12v acc to dc where does that go...and the black wire on the injector block is a ground?
Old Jan 5, 2006
let the devil out
the black wire was grounded the brown wires are tied to yoru black box and another to the positive on the battery or fues panel for injector power.
Old Jan 5, 2006
whats up with the t fitting tho on the return line is that correct?
GritzNGravy
Aug 19, 2015 03:03 AM
USCGBM
Aug 12, 2015 04:22 PM
Green02civic
Jul 27, 2015 10:48 PM
viperGTS
Jul 27, 2015 08:40 PM
