White gauge cluster for a 01 EX
Old Jan 3, 2006
catman316's Avatar
catman316 is an unknown quantity at this point
Hi everybody
I have a 2001 civic ex with the oem black gauge cluster. I want one from a 2002 (white color) all I can find are from Lx not ex as mine. will it fit? cause I think the LX dont have ABS. Olso, is hard to change the color of the backlihgt of the cluster?
Thanks
Old Jan 3, 2006
hdave's Avatar
hdave is an unknown quantity at this point
do a search of "cluster swap"
you'll be swarmed with answers to any questions you will need to ask.
i believe the answer is yes you can do that no problem, but still double check.
good luck
Old Jan 5, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Changing the backlight color and getting it to look even is somewhat involved. Better read a lot before you try it. You can also get an 03 and up cluster, but you have to re-wire the 2 plugs. Everything has been done. Wouldn't say "no problem", but it's doable.
Old Jan 5, 2006
ya its doable but the silver face 02 cluster is only from sedan. so you will need to take the cluster apart, strip off the paint on the back with acetone, put red film behind the cluster evenly, and put it all together. i did it once, and it turned out great, but it was alot of work.
raymondxcho
Sep 29, 2015 09:00 PM
hondacivic0253
Sep 29, 2015 08:06 AM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
rayman009
Sep 12, 2015 08:30 PM
