adapter for water temp gauge?
Old Dec 9, 2005
which of these would fit the upper radiator hose?
http://egauges.com/vdo_acce.asp?Subg...daptors&Cart=1
Old Dec 9, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
IIRC its a 30mm ID which is something on the order of 1 3/16. You could force the 1 1/4 in, but greddy sells 30 mm housings, they have metric threads though. If you got an autometer gauge, you're SOL.
Just gotta search around
Something like coolant temp gauge adapter or housing or "inline coolant temp housing" etc... is what they're called.
Old Dec 9, 2005
ya i know the greddy but not sure what the thread size is. i'm planning on getting vdo gauge
Old Dec 9, 2005
Jap-Euro Fusion
most of the US ones are 1/8 NPT
most of the Japanese ones (blitz, greddy, defi, apexi, etc....) are 1/8 BSPT. You can get a BSPT sensor into an NPT fitting with a lot of thread sealer, but you can't put an NPT sensor into a BSPT port.
Old Dec 9, 2005
so it won't work then. hmm. unless i buy the greddy gauge which is well over $100 and not worth it.
Old Dec 9, 2005
Jap-Euro Fusion
Can always DIY it....
Old Dec 9, 2005
im getting too old for this. care to make me something?
Old Dec 10, 2005
Jap-Euro Fusion
dude, if I still had a machine shop to go to,I'd go knock one out for you in a few hours. Unfortunately, since I graduated, I don't have that luxury anymore. I can give you the plans for mine if someone else has a shop to go to.
Old Dec 10, 2005
well i have a machine shop here in town, can i just give it to them?
Old Dec 10, 2005
can i use the stock hole? i don't think the ecu uses that to determine anything but i'm not sure. but then the dummy sensor wont work. hmm. i found one that is 1 inch adapter is that too small for the hose?
Old Dec 11, 2005
Jap-Euro Fusion
1" is too small. I'll draw up the prints this week (they're hand doodles now) and send them to you.
Old Dec 11, 2005
okay thanks. i might just get oil temp and tranny temp instead cause they are easier. i found a drain bolt oil temp plug on ebay and says for all hondas so I'll try that.
mjdiaz89
Jun 21, 2016 09:26 PM
Ronin Nishimura
Jul 28, 2015 07:24 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
silentz
Jul 9, 2015 08:16 PM
cgavin1
Jul 7, 2015 07:10 AM
