radio trim panel removal ;;help
Old Nov 11, 2005
chadhumm's Avatar
chadhumm is an unknown quantity at this point
how do i pry the radio trim panel off, ive been trying for an hour now with a knife then a credit card its not budging, im trying not to scuff it up this thing is not coming off, does anyone have any sugesstions. please
Old Nov 11, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
did you remove the screws? there are 2 on the bottom of housing, you could only access it if you take off the trim piece for the cigarette lighter. also dont pry open the trim piece as that will damage the trim finish. pull out the housing by reaching your arm to the back of the housing via the cig lighter trim piece spot. check some of the diy on this forum for more help as ppl will eventually see this and say
as you can see in my picture, the trim piece below the hvac and audio stuff, where the 12 volt socket is removed. there are 2 screws on the top of the 12 volt trim piece hole that holds down the housing.
Old Nov 11, 2005
Shpoo's Avatar
Shpoo is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...d.php?t=153830
Old Nov 11, 2005
chadhumm's Avatar
i got those 2 8mm screws off as, i have the instructions from crutchfield..step by step. im stuck there there is absolutely no room to get up there from behind. ill keep prying
Old Nov 11, 2005
mrchowmein's Avatar
try this diy:
http://www.7thgencivic.com/forums/sh...d.php?t=211259
the diy articles are in the diy forum. the link is near the top of the page.
9) Stick your hand behind the metal bar that you just took the screws out of and push it kind of up and forward. The top of this bar is part of the panel containing the head unit and the bottom half is part of the car. Push on the bar so that the head unit pops out. It may be stiff if it hasn't been removed before but it does come out.
id also add: becareful with the panel clips. since they might fall into the car. hehe
Old Nov 11, 2005
chadhumm's Avatar
thx
thx so much that did the trick. i really appreciate it . i was as careful as i could of been but 8 of the 9 clips did come off, i was able to recover 1 so i have 2 of them . ill have to try and find some of those...somewhere. thx again
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Dmitri
123
Oct 13, 2005 08:01 PM
