Engine Help ASAP!!!!
Old Nov 6, 2005
prccivic's Avatar
ok..so i was driving my 2002 ex tonight and it was choking everyonce in awhile...meaning i was driving down the road and every so often it felt like someone hit the brake pedal real quick...then later in the night, my check engine light came on and i could only go like 30mph and my car back fired a bunch of times. I relize that my problem is probably a fuel system problem. Do u guys think it is just a clogged fuel filter, or a more serious problem? Let me know ASAP what u think...thanks...
Old Nov 6, 2005
could be anything. what are ALL the mods you've done to it? try to get that code read asap.
Old Nov 6, 2005
Ichiban's Avatar
Ichiban is an unknown quantity at this point
It could be a missfireing. Check your plugs. Plugs can tell you a lot.
Old Nov 6, 2005
-throttle body heater bypass (put it back to stock)
-plugs
-idle air control valve (test by removing intake and plug the port on the left with your finger to make sure the idle drops and stalls).
-loose or corroded ground connections
-dirty throttle body (remove intake and clean with a cloth and TB spray cleaner around the sides and inside the valve, then spray on the valve hinges and let dry).
-check air filter
-make sure there are no kinks in the breather hose
-bad gas??
-clogged injectors (use www.lubecontrol.com products)
-too much carbon buildup (see above solution)
-incorrect plug torque (should be 13 ft/lbs with torque wrench)
-leaky exhaust gaskets
-short in an electrical wire
-fuel pressure too low (replace fuel pump)
-fuel filter is possible, but they go for 100k miles +
-bad oxygen sensor (they last 60k miles) would explain backfires
but we don't know which ones until you read the CEL!
Old Nov 6, 2005
prccivic's Avatar
no mods really...just intake and suspension work
Old Nov 6, 2005
prccivic's Avatar
-plugs
-check air filter
-bad gas??
there is no cell....the check engine light DOES NOT FLASH....so...
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
hmmmmmm.
You need to start with checking for codes!
Old Nov 6, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
go buy a code reader at advanced auto parts.
Old Nov 6, 2005
prccivic's Avatar
how much is a code reader...and is there a certain kind i need? Can u rent one?
Old Nov 6, 2005
MajinB's Avatar
yeah they have a rental system for there parts. you buy it, and when your done you bring it back and they give you a refund. lol. it sounds stupid but its cool cause you can use the stuff for free. go in there and tell them your car threw a code and you need a code reader. they will help you out. if you can't afford it ask if its covered under the rental thing.
Old Nov 6, 2005
prccivic's Avatar
ya..i was thinking about just going to Kragen and buying one then taking it back when i go to get the parts i need
Old Nov 6, 2005
just goto advance or somewhere else they do it for free!
Old Nov 6, 2005
Old Nov 6, 2005
ugh wtf quad post sorry.
Old Nov 6, 2005
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Jump the pins on the OBD 2 port and read the codes on the MIL light. Its free.
Old Nov 6, 2005
C Orndorff's Avatar
http://www.k-series.com/tech_detail.php?Tech_ID=CEL
Same thing with a K20 but the codes have a diferent list. i know the d17 code list is somewhere on this site.
Old Nov 6, 2005
i don't think our mil does that blinking thing.
Old Nov 6, 2005
prccivic's Avatar
I bought a code reader....it says "TDC sensor intermittent interuption"...what the hell does that mean?
Old Nov 6, 2005
tdc=top dead center referring to the piston position. it means that sensor has a problem. this is a huge deal. get it checked asap.
Old Nov 6, 2005
prccivic's Avatar
ya figured that out...thanks...i am taking it into the shop tomorrow...thaks for all your help
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
If you want to try to DIY it... Here ya go!
ID:	61918   Click image for larger version
Old Nov 7, 2005
prccivic's Avatar
^^ Wow!....thats sweet info..but unfortunatly i left my car with my parents and had to drive back to school tonight, so i can't try it...my dad is just gonna take it to the shop tomorrow. thanks though
Old Nov 13, 2005
prccivic's Avatar
Ok, so i got my car back from Honda on Thursday night, and the deal was that my idle pulley (i think) was frozen. They found that out when they went into the right side of my engine. So they fixed that and gave me a new timing belt, car runs great now. The best part is that it was FREE and my car isn't even under warrenty already. So, thanks to all that were trying to help me.
Old Nov 14, 2005
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
u said u installed a intake? well is it CAI? or SRI? did this happen right aftr u installed the intake? cuz my friend had the same problem because he mixed up his hose but its was on a GT-S
