Clutch wear symptoms
Old Oct 11, 2005
eggfooyoung's Avatar
eggfooyoung is an unknown quantity at this point
Hi everyone. I did a search on the topic and didn't get much info. I just wanted to know what are the early warning signs that your clutch could be wearing out?
Old Oct 11, 2005
crazea03's Avatar
crazea03 will become famous soon enough
when slipping occurs when accelerating
or i think also when you feel the clutch pedal grabs too far
Old Oct 11, 2005
skipbarber's Avatar
^our clutches wont show wear in terms of engagement point, because it's hydraulic.
Old Oct 11, 2005
ragingSPAM's Avatar
I just burnt my tongue
OOH PWNED!...lol jk but yea skip is right...u can tell when its starting to fade is when it wont catch as easily or u know u cant level it out cuz the clutch plate is so worn down
Old Oct 11, 2005
01redJDM's Avatar
01redJDM is on a distinguished road
floor it on third gear starting at low rpm (2000-3000) if it slips ur clutch is fvcked & u've just fvcked it up more. I think mine is already gone
Old Oct 11, 2005
pr0vidence's Avatar
pr0vidence is an unknown quantity at this point
It's weird. I bought my EX standard new. and the "sweetspot" was roughly half way up from the floor. Now its got about 12k on it. I am an experienced standard shift driver (drove stick for 5-6 years before getting this car). However, the sweetspot has slowly crept higher and higher. Now, the clutch starts grabbing when my foot is damn near off the pedal. No slippage though. I don't know what the deal is. I drove 50k+ miles on the original clutch on my Prelude. So I know my driving habits are not those that kill clutches.
weird.
Old Oct 12, 2005
cpayne5's Avatar
cpayne5 is an unknown quantity at this point
weird.
Mine has done the exact same thing. Don't know how long exactly mine's been doing it, but has definitely been a while now. 115k miles on the car.
Old Oct 12, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
mine started showing minor signs like those above, so i took it back to honda and they replaced the master cylinder. works a lot better after that.
edit: for those who don't know, the master cylinder is where all the pressure is contained in a hydraulic clutch, it is attached to the slave cylinder, which is in turn attached to the throw out fork. When pressure is exerted on the slave cylinder, it operates the fork.
Old Oct 12, 2005
lo_pro's Avatar
lo_pro is an unknown quantity at this point
the same deal is going on with mine.....i decided to say f**k it and just replace the thing.....i also get a grinding noise when i engage the clutch, but im pretty sure thats just the throwout bearing
Old Oct 12, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Just cause a clutch is hyd. does not mean it wont tell when its wearing. The point at which the clutch grabs will not be the same on any pedal including those that are hydro. Enuaging point is a tell and the fluid level is a tell and also clutch chatter is a tell. I only have 38k miles and mine chatters and the point is not as it was and the fluid is low. I believe that they put a weak clutch in these cars. I am going to keep driving mine but I am driving it easy and prolly should any way.
Old Oct 12, 2005
DDragon7's Avatar
Im new to stick, what do u mean by chatter? Plus my clutch also catches pretty high, almost when my foot was off.
Old Oct 12, 2005
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
is it difficult to change a throw out bearing?
Old Oct 12, 2005
blouisgod's Avatar
Life Begins > 6800rpms
weird.
im at 54k and i have the same issue - but if people have gone 100+ im not concerned.
anyone else have a squeeking noise when you press on the pedal that comes from inside the bell housing? i think its the throwout bearing, it sounds dry and creaky. damn i prolly should change it soon - i know theres a diy for your own clutch install.
Old Oct 12, 2005
DDragon7's Avatar
Yeah there was a thread on how to fix the squeeky clutch problem, but I havent tried it yet.
Old Oct 12, 2005
01redJDM's Avatar
mine has started squeeking too! also a whistling like sound comes from the transmision when the gears are engaged specially when the car is cold, does this mean I need a new clutch?
Old Oct 12, 2005
ashtonp's Avatar
nah man! the whistling is ur alternator, u have a system dont you? check the ICE and Electrical forum to find out how to get rid of that.
Old Oct 12, 2005
blouisgod's Avatar
im pretty sure thats for the noise inside the car. this is in the actual trans.
Old Oct 12, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
There is DYI for the squeking actually in the transmission.( Relating to the depressing of the clutch). It has to do with the contact points needing lubricating Do a search. http://www.7thgencivic.com/forums/sh...+clutch+grease
Old Oct 12, 2005
01redJDM's Avatar
Yes I have a system... are u sure its the alternator? it just makes that sound when I rev the engine at gear, it doesn't do it in adle
Old Oct 12, 2005
cdmx's Avatar
hehe see how much you can chirp in 2nd and that will tell you
Old Oct 19, 2005
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
I have a 2001 sedan and just turned 100k miles. For the past year the clutch has been really grabby, there isn't much modulation in the clutch. There has been this Grinding/Rattling noise for the past few months that is very noticeable from inside the car when accelerating or decelerating, almost like the gears are worn or something. It’s the most noticeable in 1st, 2nd and 3rd gears. Now for the past couple days it’s starting to make a similar noise when the car is parked, idling. The noise stops when you press in the clutch, and then starts when released. I’m going to replace the clutch and stuff soon, what would be causing this sound? Is it the syncros or something?
Thanks
EDIT: Also off the subject.. my AEM Short Ram Intake just cracked at the mount (I'm guessing from vibration or something, I'm going to use a rubber gromet when I put it back on). Do these things have a warranty? If not I'm just going to have my brother weld it.
Old Oct 20, 2005
cg95660's Avatar
Well chatter is when you try to smoothly let out the clutch and you can feel a jerky motion and or jerky motion in the car. Some times chatter is really light. My ingage point is high too and my fluid level is lower a bit meaning the clutch disk has worn down. I only have 38k miles. But after I got my revo and i/h/e it seems that it is very hard not to power shift second. Soone too many second hits for me has made my clutch weak. Now I could easily keep on driving it easy and get alot more miles on this clutch but i prefer to get it changed and have the upgraded clutch. As for the noise when depressing the clutch is going to be the t.o.b.(throw out bearing) and most of them are a sealed bearing and some are not. Dragon7 I would say you are in the same boat as me just save up for a new clutch and change it. I do not think its a major problem now but it gives you some time to save up. I hear the exedy organic is good so I think I will run that one.
Old Oct 20, 2005
cg95660's Avatar
Thanks
That sounds like tranny bearings. The bearings on the main shaft get noisy when worn especially at idle(not too much fluid movment). Manual trannys can go quite along time worn I say if you are past the warranty drive it till it pukes lol.
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
adamdrives
15
Aug 8, 2015 08:53 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
