Tips on driving manual?
dont drag the clutch alot, and when youre slowing down, try using the breaks and downshifting 1 gear.. if your goin 40 slowin down , from 4th gear, down shift to 3rd gear around 33-34mph while youre braking.. same thing for each other gear. thats how i do it , and not a problem yet, and makes speeding up after i slow down easier and cleaner on the tranny
new question.
Is it bad to shift to fast from 1st to 2nd or 2nd to third or whatever, like do you have to let the rpms drop before letting off the clutch when shifting gears. i know it will make the ride smoother but in my car its a lil bit slow to drop the rpms after about 3-4k rpms.
Drunken Master-7thgen Ninja
Originally Posted by DDragon7
But if u shift too fast it will jerk.
you can always make it smooth, at lower rpms you have to shift different than at high rpms. Of course you can shift real fast at high rpms to chirp the tires, and that is a big jerk, or can shift at just as high rpm and not jerk or perch the tires.
^Yeah this is enough...
Ok, if you shift to fast that the revs won't match you're putting stress on the clutch, but even more on the synchros. Like someone said, you're not racing all the time. Let the synchros do their job and it will save you money in the future on fixing them or possibly a trans rebuild.
Originally Posted by CuRiOuSfIsH
not bad for the car, just wear out the clutch faster as you said.....
as for driving in traffic, stay a good distance so you wont have to constantly engage and disengage the clutch..... which could lead to tiring out your leg and wearing out clutch.
^^So your not rev-matching?
I could be doing something totally bad, and if I am and learned the proper way I would try and alter my driving habits. I don't want to ruin my engine. =)
this an interesting thread. i for one had to go about learning manual by myself. i've only been driving stick for little over a year now and i'm probably bringing along bad habits too since i never had a pro stick driver teach me the way....
my car is only 20k miles and since its my first stick i bet the clutch is taking wear as if it was like 50k+ normal wear LOL (damn....)
i always press the clutch pedal all the way down when shifting too
what i don't understand is this skipshifting. when i upshift, i always go in order. but when i downshift i sometimes skip downshift because i need the extra stopping power.
what's this rev match? how do you do it? i really want to know. because whenever i downshift to slow the car i always press the brake simultaneously (to slow down the car) and slowly let the clutch out so the car doesn't jerk....
as for traffic, i'm lost on that. i have bad control on stop and go traffic and also on stop signs. it's hard to explain. but i guess my best example is like doing a rolling stop at a stop sign with an automatic. i find it hard to do a rolling stop with a stick because i end up starting at 1st again while the car is rolling a little bit and then i either gas it up from there or go to second without gassing if the rpms are high enough. either way i jerk.....(how sad!)
more on traffic, it's really hard to follow the car in front of you when rolling in 1st or 2nd gear. if the rpms go low the car starts to vibrate or it kinda does a back and forth motion (almost like a soft jerk back and forth)
oh yea for downhill. i guess i'm a slow learner and most of you probably know this but if you're at a stop in a downhill, just let go of the brake pedal and let the car roll in this neutral state to get the rpms up and shift to 2nd....
i'm wondering if this is the only case where skip upshifting is good.
as for clutch riding. i only seem to ride the clutch when i'm going in reverse. because if i let the clutch pedal all the way out then it goes too fast. i just make it half way and gas a little to get it moving.
btw, i hope you guys put more info on this thread as much as you can. i'm definitely bookmarking this
p.s. i really want to learn this rev matching, heel-toe, double-clutching, etc.
oh yea, what's powershifting? my friend says its when you shift without pressing the clutch. how is that possible to do and why would it be done?
To go the fastest in our cars you wanna shift at redline, it has been proven because even though power drops off very slightly around 6500, you wanna be at higher rpms for the next gear.
Check out this thread-nothing to do with high rpms just driving clutch
http://www.7thgencivic.com/forums/sh...d.php?t=242566
I engine brake all the time. I ease off the clutch when I do it though. You can't do it hard. My 96 HX had 215k miles on it and never had the clutch replaced and I always engine brake before using the brakes. Basically for stuff like slowing from 70 to 40 to go through epass tolls. it just seems natural to slow the car down that way rather than braking then downshifting then braking and downshifting again.
the clutch isnt working as a brake pedal.. the clutch engeges the engine which under 0 throttle is revving down. this is engine braking. the clutch is only doing its job, nothing more, nothing less.
down shifting isn't bad. just make sure you aren't in too high of an RPM range when doing it. i down shift and brake at the same time sometimes when i've been going too fast and need to come to a quicker than usual stop. just make sure you're using the break also while downshifting. you can't just downshift while in highass RPM's and not use your breaks. thats stupid. but i don't downshift alot with my car cause i don't drive very fast in the first place. so i just need my break pads. i use REAL breaking about 98.9% of my driving. not downshifting.
Wish I had a Turbo
