THE nitrous post
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
<< BAK - sulfer smell good to you???? [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] >>
I fill my tank with medical grade. its only 75 cents more per LB, but i can sell it for 3 bucks a baloon to dumbass high school kids at partys and make 2000X my money back. That plus you can run your N20 lines without the restrictive filters which boosts line PSI and max flow rate.
2k1civic.com O. G.
can some one please make this stickyy?? if it has not already been done
becuase as of right now.. this is the only way the D17 can make any real power... swapps... turbos... superchargers.. bahh.. still a ways off...
Support your local 81
From: In the land of milk and butter, Massachusetts, US
Quote
[hr]Originally posted by: JoeB16
Is n2o dangerous
[hr]
Is n2o dangerous
[hr]
Quote
[hr]Originally posted by: bhaz413
i hope you dont say you wrote this your self, or anything. this post was taken from Club si, in the N20 forum. LAME[hr]
Quote
Is n2o dangerous
[hr]
Is n2o dangerous
[hr]
Joe,
In the post you talked a great deal about the NOS and Zex kits which is great. Since you seem to have a good deal of knowledge about nitrous setups what do you think about the Nitrous Express kits that are available. I've heard from many sources that it is a great kit for our cars and it was the one I was considering getting down the road. How would you rate it among the other kits that are available.
-Numinous
-Numinous
Quote
[hr]Originally posted by: CaLiBoY
hey guys.....i have NO engine mods at all
what mods should i get if i get NOS?
do i need headers,intake, and exhaust?
thanks
daniel[hr]
thanks
daniel[hr]
-Numinous
Quote
[hr]Originally posted by: NeoMagus
Jesus christ man. Have the n00bs wont have a clue what you just posted.[hr]
just because someone is new doesn't meant they don't know about cars man. come on!
Quote
[hr]Originally posted by: Numinous001
Joe,
-Numinous[hr]
Joe,
-Numinous[hr]
NX and NOS are about = IMO.
i boogie for the raindrops
anyone know if the NX incognito kit works?
NX incognito kit
NX incognito kit
Ok...I dont want to be mean but not all of that is too correct.
WET - Simply means you spray fuel and N2O
DRY - Is ONLY N2O
When you said wet sprays fuel to MATCH N2O thats wrong. Different Jets allow different amounts of fuel and N2O
When you said DRY is when vacume is adjusts fuel pressure to have the injectors spray acoordingly... Maybe thats how Zex works but I damn now NOS doesnt do that, and also that would be controlled by the comoputer.
The correct size shot.... For a car with NO internal mods... It is ONLY RECOMMENDED to spray 1/3 of the cars STOCK HP
I.E. a reg. civic with 115 HP STOCK should only spray a 38 or 39 HP shot... But lets get real 40 definately wont hurt... but yes you can easily run 40,45,50,55 stock.
What is recommended to use with N2O...
New Clutch....Kiss It... Stock clutch is 100% fine for 40-55 shot.
Fuel Pressure regulator....Doesnt do **** (am I allowed to say that)
Get an Air/Fuel meter and then decide wether fuel pressure needs to be changed, I garuntee you wont need to.
Now whether to go DRY or WET. Dont ever recommend DRY, you are correct that DRY is OK for small shots but if you ever wanna go higher, you are gonna WANT WET in fear of leaning out.
Maybe you can explain why with a wet kit all of a sudden you need a fuel pump and new motor mounts...
WET is SAFER and better for your car.
You wont need a fuel pump unless your car cant pump enough fuel, that would require a big shot of N2O.
And Motor Mounts...... ummm NO!
WASTE of $$$$$$$. if you are only spray these shots under 100.
PLUGS though... PLATNUMS are a "NO, NO"
You want coppers, get some NGK's people's. After you use N2O a while you will understand alot...
And you do not need to adjust your timing... plus you didnt make it clear what timing
CAM, IGNITION, CRANK ?????????
But NO timing adjustment will be needed...
CAMS... If you bought cams and are deciding to use Nitrous, you might wanna ask someone if its ok to spray on those cams.
Many times when people buy cams, you are asked if you are under any type of boost. B/C you get SPECIFIC CAMS for your application...
i.e under Nitrous, Turbo (spec PSI) and same for Supercharged cars.
Are any other mods recommended with Nitrous again... If you use Nitrous and you have a header you might find something interesting.
Go to a dyno... Dyno the following...
STOCK
WITH HEADER (aftermarket)
N2O with STOCK exhuast manifold (header)
N2O with Aftermarket Header
you can notice that under N2O the header makes a bigger differnce.
let me explain.
Say over stock the header gives you 20 to the wheels
Now Stock header with N20 you get 50 HP on a 50shot
You'd think that Header and N2O you will gain 70HP
But with both working together you will actually see a bigger gain such as 80 or 85.
If you want me to explain, please e-mail me but its a LONG explaination why.
Your not exactly correct on where to place the nozzle...
TOO close to the throttle body can be not to your like'n. You want the nozzle to be 4" away from the T.B. You may give or take an inch at most. There is another long explanation for this too, please feel free to e-mail, but im just stating facts.
JOEB16 good job on explaining the diff between many of the kits and Jets for each shot.
Sorry im pickin on ya for some of the other stuff. [IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/demon.gif[/IMG]
I go to school in Orlando so any locals wanna meet im down. This Fri and Sat are very good, i live @ UCF [IMG]i/expressions/face-icon-small-puke.gif[/IMG] but you can IM me on AOL on DJ CYCLONE 1969. Hope to see some quick N2O civics soon.
DRY - Is ONLY N2O
STOCK
let me explain.
blingbling member
is it a good deal to get NX nitrous with bottle heater,purge,and all the complet kit install for 800 dollas?!?!?......
im i getting hipped off or not?!? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Quote
[hr]Originally posted by: TheFastLegend
DRY - Is ONLY N2O[hr]
Quote
[hr]When you said wet sprays fuel to MATCH N2O thats wrong. Different Jets allow different amounts of fuel and N2O[hr]
Quote
[hr]When you said DRY is when vacume is adjusts fuel pressure to have the injectors spray acoordingly... Maybe thats how Zex works but I damn now NOS doesnt do that, and also that would be controlled by the comoputer.[hr]
These are three basic types of nitrous systems: dry, wet, and direct port. The most misunderstood is the "dry" type of system. A "dry" nitrous system simply means that the fuel required to make additional power with nitrous will be introduced through the fuel injectors (remember, fuel makes power, nitrous simply lets you burn more of it). This keeps the upper intake dry of fuel. We accomplish this by two methods. First, is to increase the pressure to the injectors by applying nitrous pressure from the solenoid assembly when the system is activated. This causes an increase in fuel flow just like turning up the pressure on your garden hose from 1/2 to full. The second way we can add the required fuel is to increase the time the fuel injector stays on. This is accomplished by changing what the computer sees, basically tricking the computer into adding the required fuel. In either case, once the fuel has been added, the nitrous can be introduced to burn the supplemental fuel and generate additional power.
Quote
[hr]The correct size shot.... For a car with NO internal mods... It is ONLY RECOMMENDED to spray 1/3 of the cars STOCK HP
I.E. a reg. civic with 115 HP STOCK should only spray a 38 or 39 HP shot... But lets get real 40 definately wont hurt... but yes you can easily run 40,45,50,55 stock.[hr]
Quote
[hr]What is recommended to use with N2O...
Get an Air/Fuel meter and then decide wether fuel pressure needs to be changed, I garuntee you wont need to.[hr]
Quote
[hr]Now whether to go DRY or WET. Dont ever recommend DRY, you are correct that DRY is OK for small shots but if you ever wanna go higher, you are gonna WANT WET in fear of leaning out.[hr]
Quote
[hr]Maybe you can explain why with a wet kit all of a sudden you need a fuel pump and new motor mounts...
WET is SAFER and better for your car.[hr]
Case in point:
My Si has to turn 3-4 times when starting with under 1/4 a tank of gas. Why? Crappy fuel pump. What fixed it? Im sure you can guess.
Quote
[hr]And Motor Mounts...... ummm NO!
WASTE of $$$$$$$. if you are only spray these shots under 100.[hr]
Again, case in point:
Id get wheel hop spinning my tires on wet streets in stock form. Added 30 dollar mount inserts, can now drop clutch @ 8K RPM with nothing but wheel spin.
Quote
[hr]You wont need a fuel pump unless your car cant pump enough fuel, that would require a big shot of N2O.[hr]
Quote
[hr]PLUGS though... PLATNUMS are a "NO, NO"
You want coppers, get some NGK's people's. After you use N2O a while you will understand a lot...
CAM, IGNITION, CRANK ????????? But NO timing adjustment will be needed... [hr]
As for the rest:
Updated for clarification
Quote
[hr]CAMS... If you bought cams and are deciding to use Nitrous, you might wanna ask someone if its ok to spray on those cams.[hr]
Quote
[hr]Many times when people buy cams, you are asked if you are under any type of boost. B/C you get SPECIFIC CAMS for your application...
i.e under Nitrous, Turbo (spec PSI) and same for Supercharged cars.[hr]
Quote
[hr]Are any other mods recommended with Nitrous again... If you use Nitrous and you have a header you might find something interesting.
STOCK
you can notice that under N2O the header makes a bigger differnce.[hr]
STOCK
Quote
[hr]let me explain.
If you want me to explain, please e-mail me but its a LONG explaination why.[hr]
[hr]let me explain.
Quote
[hr]Your not exactly correct on where to place the nozzle...
TOO close to the throttle body can be not to your like'n. You want the nozzle to be 4" away from the T.B. You may give or take an inch at most. There is another long explanation for this too, please feel free to e-mail, but im just stating facts.[hr]
-back from the dead one more time
joe if u dont mind answer couple questiosns.
1. i got intake, header, exhaust. planning to do 50shots...no more for sure. should i get wet or dry?
2. need any more prep?
3. dont spray everyday, wat do i need to check for lean? or other signs of dmg?
4. wat brand u prefer?
5. anything else i should know?
Quote
[hr]Originally posted by: iluvbritney
5. anything else i should know?[hr]
2. Buy NGK-BKR7E spark plugs. You can buy them cheap @ summitracing.com. Use that EXACT part number in your search. You need 4 of them obviously, and gap them to your stock specifications. This information can be found in your owners manual. As far as other "prep", I reccomend an upgraded clutch if you dont already have one and a bottle warmer. You should also get a nitrous pressure gauge. NOS makes a good one that fits on your bottle. This can be bought at summit for under 35 bucks.
3. Although you have to spend upwards of 300 bucks on a GOOD AF gauge to do actual TUNING with, a cheap auto meter can and will let you know when you are running way too rich or way too lean. These really are the only things you need to be concerned about when trying to prevent damage. Also, check your spark plugs after running your N20. Detonation will cause small metal bits to become fused to the metal on the plug. If you cant wipe them away then probably bits of your internals being fused to the plug... which is bad. Although catching it early will save you a LOT of money, so CHECK EM! Also the color of the plugs can tell you if you are running too righ/lean, but thats more complacated and is an issue for a completly different post. Plus, id need to find pictures to post.
4. NX and NOS nitrous. Zex sucks ***. I have actually personally had problems with their equipment. Venom is too much money, and the ECU box is just another thing to screw up and go wrong.
5. Have it installed by a professional, dont abuse it, check your plugs after you spray, REPLACE the plugs after you make hard runs on the N20 (might be better to buy 8 or 12 plugs at once, i usually buy a box of 50) and you shouldnt have any problems. Oh and install the tank in your trunk. Even if bolted down correctly that thing can and will fly out of its mounts in an accident and getting hit by a flying 15+ Lb steel tank ISNT fun.
Oh... ALSO about the bottle warmers...
NOS makes a kit, and you will notice its cheaper then the NX version. By far. This is because its based off of tempature while the NX version turns on and shuts off based on bottle pressure. The advantage of the NX being that you can always maintain the optimal pressure of 900 PSI, where as with the NOS tempature based heater, you might not get the optimal pressure when the amount of N20 in the tank falls below the volume needed to create 900 PSI at 85 F (which is the default tempature on the NOS kit, and no it isnt adjustable). The down side? The NX heater is 100+ more.
My solution? Buy the heater Im using. Half the price of the NX heater, but with all the features and then some (actually is more adjustable and made from better materials). Here you go.
http://www.speedshop.org/store/scrip...p?idproduct=17
Quote
[hr]You are half right sir, as am I. However MY set up consists of the former method, not latter. FROM THE NOS NITROUS WEB PAGE:
These are three basic types of nitrous systems: dry, wet, and direct port. The most misunderstood is the "dry" type of system. A "dry" nitrous system simply means that the fuel required to make additional power with nitrous will be introduced through the fuel injectors (remember, fuel makes power, nitrous simply lets you burn more of it). This keeps the upper intake dry of fuel. We accomplish this by two methods. First, is to increase the pressure to the injectors by applying nitrous pressure from the solenoid assembly when the system is activated. This causes an increase in fuel flow just like turning up the pressure on your garden hose from 1/2 to full. The second way we can add the required fuel is to increase the time the fuel injector stays on. This is accomplished by changing what the computer sees, basically tricking the computer into adding the required fuel. In either case, once the fuel has been added, the nitrous can be introduced to burn the supplemental fuel and generate additional power. [hr]
TheFastLegend,buddy of mine is haveing loggin issues, but would like to apologize. "I thought that he meant the kit adjust the Fuel Pressure and that, DUH the stock copmuter with adjust the fuel pressure to keep an even Air/Fuel ratio"
Quote
[hr]Originally posted by: LeroyBrown
NEX is definately the way to go..[hr]
