Checking your MPG?
Old Jul 16, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
Checking your MPG?
Is there a guage that you can add to your car that will tell you how many miles you can go on a tank of gas, how many miles per gallon you are using, and how many miles per gallong you have used?
Old Jul 16, 2005
aoar's Avatar
aoar is an unknown quantity at this point
simplest way is a calculator at the pump/ resetting your trip meter.
Old Jul 16, 2005
k20txem2's Avatar
yeah i know about that, but what about like something that like dodges and fords have, that little trip meeter thing?
Old Jul 16, 2005
streetglower's Avatar
we have trip meters too. Just reset it to zero when you fill up. Then the next time you need gas, just take the mileage you had and divide that by the number of gallons you filled up.
Old Jul 16, 2005
aznrocka's Avatar
aznrocka is an unknown quantity at this point
He's talking about one that calculates while you drive...it gives you mpg est for the tank, mpg you've used, mpg you approx have left, etc.
Old Jul 16, 2005
k20txem2's Avatar
Yeah bassically something that can do it on the fly? not doing the caculator thing.
Old Jul 16, 2005
Maurizio's Avatar
Maurizio is an unknown quantity at this point
That would require a a device with inputs from your speedometer, odometer, fuel tank float, RPM and/or fuel pump/line.
Old Jul 16, 2005
k20txem2's Avatar
Does this device exsit?
Old Jul 16, 2005
YS's Avatar
YS
YS is an unknown quantity at this point
http://www.thinkgeek.com/gadgets/electronic/72fc/
Scan Tool
Reads Trouble Codes
Reads conditions that set the Trouble Code
Clears Trouble Codes
Turns off "Check Engine" light
Make and store up to 10 rewritable special codes to send to the vehicle computer
Digital Gauges - Shows 4 gauges at a time from the possible following:
Fuel Economy (MPG - gasoline engines only)
Fuel Rate (GPH - gasoline engines only)
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Trip Computer
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used (Gasoline engines only)
Trip Fuel Economy(Gasoline engines only)
Old Jul 16, 2005
k20txem2's Avatar
Sweet thanks YS, to bad thats kind of ghetto looking lol, but might be able to work with it as a starting point.
Old Jul 16, 2005
SlowStockCivic's Avatar
SlowStockCivic is an unknown quantity at this point
My old 97 GTI VR6 and 91 Passat 16v oil temp, trip, MPG (kilometer per litres here in Canada), thermometer, average speed all built in. I would always try to see what my best MPG would be. I really miss that feature.
Old Jul 16, 2005
zen_master's Avatar
if we can simulate the one in Civic Hybrid, that'll be c000l
Old Jul 16, 2005
k20txem2's Avatar
yeah thinking about getting that one up there, then molding in to the car with a better lcd.
Old Jul 16, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i like the one on bmw's you can watch yourself f off your gas milage to under 10 in reverse
Old Jul 16, 2005
dalaw's Avatar
Bone Stock!
It would be nice if we have the mpg meter like the hybrid. Instantaneous mpg is what i am after so i can drive at speeds that gives max mpg on different roads.
Old Jul 17, 2005
zen_master's Avatar
anybody try to swap it? hehe
i believe hybrid's meter probably only controled by information from ECU...no mumbo jumbo behind it..
if that's true, then it's possible to use that on our vic?
Old Jul 17, 2005
k20txem2's Avatar
You got a picture of this hybrid gauge you speek of?
Old Jul 18, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
This?
I had a car with a fuel economy gauge. Basically, it told me that when I was pressing on the gas pedal I was getting poor fuel economy and when I let off the gas pedal I was getting good fuel economy.
Old Oct 17, 2005
zadscmc's Avatar
zadscmc has a spectacular aura aboutzadscmc has a spectacular aura aboutzadscmc has a spectacular aura about
Another picture of the hybrid dash:Click image for larger version
Name:	HCH 050812 Best Tank.jpg
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
