turbo and gas mileage
Old Jan 21, 2002
scsikid's Avatar
scsikid is an unknown quantity at this point
seeing as i dont exactly understand how turbo works i thought i would ask this question. if you have a stock engine and add a turbo.... does that give u worse gas mileage? or is it unaffected.
i would figure it would be unaffected because doesnt turbo just push more air into the cylinder? in which case its not that your adding more gas into the cylinder.... just more air... more O2 right?
i guess the only way it would decrease your mileage is cause of higher revs.... higher revs means worse mileage right?
people confuse me!
Old Jan 21, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
guy of course you gonna eat more gas on your car..and yes less millege..my friend has a turbo si..don't know how many psi..only 250km one tank..
Old Jan 21, 2002
Grey's Avatar
DIY King
No. Don't theorize when you really have no idea. It sound lame. Sorry dude, Ihad to say it.
A turbo turns by way of the exhaust gases, so it doesn't rob your car of as much horsepower a supercharger would (which turns off of being hooked up to the crank shaft). However, a turbo blocks the shockwave tuning effect in an exhaust which adds power. Anyway, got sidetracked there for a moment. Adding air in and of itself beyond the amount required does not help. You need to add in fuel too. A turbo adds in the air, but the ECU senses that air and adds some gas so that the air/fuel ratio maps for the various rpm ranges are balanced out.
It's all about forcing in more fuel and air into the combustion chamber. That creates a bigger bang and more power.
Old Jan 21, 2002
1028CiViC's Avatar
so that means it will use more gas..haha.
Old Jan 22, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Simple, more air or less air restriction, the ecu will compensate with gas, plus everything else Gray said!
Old Jan 22, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
plus if you had a turbo, you know damn well you'll be reving so much to spool that thing
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
jody501
Jul 10, 2015 11:01 AM
cgavin1
Jul 7, 2015 07:10 AM
