DIY squeeky clutch problem HELP FAST
Old Mar 12, 2005
Stylingcivic's Avatar
Stylingcivic is an unknown quantity at this point
I was doing the DIY clutch sqeek put it back together and now my clutch pedal has no resistains. please help!!!
Old Mar 12, 2005
sw388integra's Avatar
did you wd40 it?....mine did it when it was wet outside, i put wd on it, and it was squeekless
Old Mar 12, 2005
Everything was lubricated but there seems theres no pressure in my pedel. I do know that there has to be pressureized because it uses brake fluid.(its got a hydraulic clutch) I tried to start my but nothing would happen. How do I get pressure to my clutch?
Old Mar 12, 2005
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
did you try bleeding it?
Old Mar 12, 2005
Thats what I'm just about to try. How do I do that? If that doesn't work any other suggestions.
Old Mar 12, 2005
Logan3024's Avatar
Sounds like the slave isnt pushing against the clutch fork.
Old Mar 12, 2005
It is. I'm bleeding it and all I need is some more fluid which I'm going to get.
Old Mar 12, 2005
I bled the lines but the clutch has no pressure. Imust not be doing this correctly.
duder
15
Jun 11, 2015 04:28 PM
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
BootyDo
May 7, 2015 04:46 PM
bsmiley
Apr 27, 2015 01:27 PM
