can i get my cam gears ajusted, to add more HPs
Old Jan 1, 2002
phillip's Avatar
phillip is an unknown quantity at this point
i was wondering if i can ajusted my cam gears, so i can add more HP's to my 2001 civic, i ask becuse my cuz has a 98 crx with a si swap b-17, 178 hp's, v-tec controler, but no torbo or supercharger but does run a 15 in a qurter mile race, but anyways, he raceed a stock 99 prelude but with ajusted cam gears and bet my cuz crx, so i was wondering if we can do it on the 2001 honda civic. THANKS MAN!!!!!
Old Jan 1, 2002
Cole's Avatar
Cole is an unknown quantity at this point
if ya have adjustable cam gears, you can have them adjusted to give a little bit of HP addition
Old Jan 1, 2002
Grey's Avatar
DIY King
The stock cam gear (no s because we only have one cam shaft) is not adjustable. At least I don't think it is. Even if it is, then it's not built to be adjusted frequently. I'de get AEM's adjustable cam gear. They just came out. I'm not aware of any place that sells them yet, but their here on AEM's site: AEM Cam Gears Part number 23-605.
Old Jan 1, 2002
CapYoda's Avatar
Escaped Convict
from my understanding.. adjustable cam gears can only adjust ur power curve.. as in, you move the power output up or down the power curve...
you wont make more horsepower.. but u can adjust where u want the most horsepower/torque at what rpm and etc.
Old Jan 1, 2002
ayzan's Avatar
ayzan is an unknown quantity at this point
CAPYODA is correct....Cam Gears do not add any horsepower. What it can do is adjust your powerband. Keep in mind, if you adjust the power band to lower rpms, your higher rpms will suffer. Vice verse if you adjust towards the higher rpms.
Old Jan 1, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
in a dohc motor you should be able to increase the valve overlap giving more power at high rpms - this isn't true with a sohc motor because the lobes are fixed.
Old Jan 1, 2002
Khaos3001's Avatar
Khaos3001 is an unknown quantity at this point
Cam gears for our cars WONT WORK! The ECU will compensate for the cam gears and you will end up gettin no difference in performance whatsoever...
Old Jan 1, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
i would say something but i'm not too sure about cam gears so i would advise you to search
Old Jul 21, 2002
HondaLuver's Avatar
Its a celebration bitches!
just by putting on a cam gear will increase your hp and tq. it is like a pulley... if you really want to adjust it you need to go to a professional with a dyno and he can give you the max hp and tq.
Old Jul 21, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
Quote
[hr]Originally posted by: HondaLuver
just by putting on a cam gear will increase your hp and tq.[hr]
no
Old Jul 21, 2002
Grey's Avatar
DIY King
Only if it's lighter would be more accurate.
Old Jul 21, 2002
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
can adjusting the AEM cam gear ruin/brake anything?
Old Jul 21, 2002
Grey's Avatar
DIY King
Yep. I'm not sure what the level of adjustment is on that particular brand of cam gear, but technically you can adjust it so that the valves open at the wrong time and they get hit by the piston. That's an extreme case though. You can also adjust it so that the intake valves open too late and you get an air/fuel mixture that gets backwashed into the intake manifold by the piston as it's moving up. That could cauuse your intake manifold to explode if there's a stray spark. All sorts of stupid things. The best way is to either get one and leave it alone (gaining torque from the fact that it's lighter) or to get one and adjust it one degree advanced timing. That's very safe to do and I think you'll gain a little torque (power) by doing that. The best way is to get one and get your car on a dyno jet. Then measure the horsepower vs. detonation that you get by advanced timing. Try higher octane gas to advance it even more for higher horsepower gains. Blah blah blah blah blah...
Old Jul 23, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
The came gear does add HP and torque, it says so right on aem's website. I have mine on order and it is coming in tomorrow, I will post results. Also Why would they make it for our car if the ECU makes it not work.. I don't think some of you know what you're talking about! Get your facts right before you post some BS...
7thgensurvivor
Aug 26, 2015 06:17 PM
WaryDriver
Aug 16, 2015 11:22 AM
Masaru
Aug 10, 2015 06:20 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Ccoop87
Jul 9, 2015 03:26 PM
