help with hyperblinker
Old Feb 16, 2005
kasimmmmm's Avatar
Hey,
I have a hyperblinker and want to install it... I have no idea where it goes.
I'm suppose to find the "relay" and replace the original one with the one I have. Does anyone know where the relay is????
thanks in advance.
Old Feb 16, 2005
QBoi's Avatar
Wrong forum...
Old Feb 16, 2005
kasimmmmm's Avatar
my bad...
Old Feb 16, 2005
hotrodcivic2004's Avatar
my civic has no boost
i got a right hyperblinker and didnt even pay for it....just broke somethin.
Old Feb 16, 2005
AlienX's Avatar
AlienX will become famous soon enough
the reason yours is turning on because the relay sees that there is a non OEM voltage running though the circuit and it turns it on as an indicator that your bulb(s) are burnt out. This can also happen if you are running LED bulbs or non OEM or water.. there are a lot of possibilities, but ur relay is not f*cked.
Old Feb 16, 2005
AlienX's Avatar
Originally Posted by kasimmmmm
Hey,
thanks in advance.
The answer is !!!
Follow the clicking :P really... thats where the relay is. Turn on your turn signal and follow.
Old Feb 16, 2005
PunkingCivic's Avatar
I need TP for my bunghole
ok
1. Just right of the gas pedal there is a black fuse box.
2. Then look for a screw or bolt that needs to taken off.
3. once that is done the box slides down.
4. Then look for the bliker relay. It will look like the one you need to put in its place.
5. Turn the car on to test it.
6. If all is well, slide the box up and replace the bolt or screw and your done.
Old Feb 16, 2005
2K1Civic17"Gabe's Avatar
cant you also throw a resistor under the fuse or something (the wiring that is), and control how fast you want it, but it has to be at a certain resistance or something.
Old Feb 16, 2005
AlienX's Avatar
no, no resistors in fuses.
The DIY way is to take apart the relay and you swap out the resistor to a smaller one. Reason for this is to increase the speed the capacitor charges up activating a blink.
http://www.7thgencivic.com/forums/sh...80#post2029780
This DIY is a bit diff but same idea. Enjoy
Old Feb 16, 2005
i know wut i did. i snapped the seating for the bulb, i have to get a new seating for it
Forum Bot
Lighting DIY
Dec 5, 2016 05:19 PM
FALKEN
24
Jan 31, 2007 03:23 AM
Jonauto
Nov 12, 2003 10:04 PM
DPRcivicSedan
Transaction Feedback
Jul 5, 2003 01:18 PM
zackde
Feb 21, 2002 10:49 AM
