How hot does header get?
Old Feb 10, 2005
I need to paint some of my header with hi temp paint (1200) and was wondering if that would be good enough?
Old Feb 11, 2005
Al Gore FTW's Avatar
jdmtytedoridori
I'm not sure, but I was driving last week up some moderately steep hills, going about 50-55, in 2nd (manual), for about 40 seconds at about 5500-6000 rpm.
At the top of the hill was my destination (Blockbuster) and I got out and it smelled hardcore, so i popped the hood and my header was glowing red.
I would have guessed it was over 1200 degrees, because i could feel it radiating from about 4 feet away and it was like 20 degrees outside.
Old Feb 11, 2005
Ya I've heard about that red hot glowing before. Let me guess...you have an LX? I think that's more of a problem on those for some reason.
Old Feb 11, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Headers are extremely hot. Even if you touch it slightly and take your hand off, your hand will burn.
Old Feb 11, 2005
streetglower's Avatar
if your header was glowing red, then you have a restriction in it. That isnt normal. A header shouldnt be running to the point of glowing red.
Old Feb 11, 2005
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
Exclamation
Glowing red???? I have an LX and I had the same problem......it was clogged up...thats why I got me some headers and cat-back!!!! I was loosing power!!!!!!!
Old Feb 11, 2005
TheSmuggler's Avatar
That vid of the boosted k20 in the civic, holy crap those headers looked like lava they were so red lol.
Old Feb 11, 2005
soo can anyone answer the question? lol
Old Feb 11, 2005
I would say no you can't paint them period. I remember some guy tried to paint them red and they faded and turned orange because of the heat
Old Feb 11, 2005
Logan3024's Avatar
Gearbox, 1200 isnt gonna cut it! You have to get flame proof coating,
http://www.truckcustomizers.com/prod...4VHT951.1.html
Old Feb 11, 2005
Thanks for the link. Hmm well I painted already inside the ports I widened. Is there any harm in just leaving it like that, or will the metal rust from the inside?
Old Feb 11, 2005
Logan3024's Avatar
gearbox i hope you didnt trim to much off, metal expands when its hot so i hope you didnt go overboard or your gonna get cracks at the welds eventually. Post some pics im very cuirous!
Old Feb 11, 2005
Well the tubes were originally bigger than that piece they're welded to. So I trimmed around it a little, prolly not more than a couple mm. I didn't trim into the welds at all, just the top partto make it even with the tubes. Also the dremel slipped and that's what those lines are on the surface. They feel smooth so I'm hoping it'll still seal properly. You can see where I painted around the inner ring so the bare metal gets covered. I don't want the paint to turn to liquid or something tho.
Old Feb 11, 2005
jgoodfella1's Avatar
jgoodfella1 is an unknown quantity at this point
I think thermotec makes a spray coating for headers. It can be used on their wrap or on bare metal. Rated at 2000 degrees.
Here's the link!
http://www.thermotec.com/products/full/12001/12001.html
Old Feb 11, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
off topic but, does anyone remember that post when some painted their brake calipers AND DISKS red with regular spray piant?
Old Feb 11, 2005
wonderz's Avatar
wonderz is on a distinguished road
who painted to their disks? wouldn't that affect the braking, and its gonna fade anyways once you use the brake.
Old Feb 11, 2005
KalliGarri's Avatar
yup.. everyone was making fun of his for doing it
Old Feb 11, 2005
SMX's Avatar
SMX
SMX is on a distinguished road
Spray paint on a header is slightly better than using hair spray. If you're serious, get them ceramic coated. Otherwise plan on replacing your painted header every 2 to 4 years or so depending on weather and use.
Old Feb 11, 2005
Okay first off, the header is already coated from the company. Second, I'm talking about hi temp paint (not regular), and third, I'm only painting inside the ports where I dremeled. Can someone answer that?
Old Feb 11, 2005
CdKoInU's Avatar
CdKoInU is an unknown quantity at this point
will painting the heat guard (for stock EX header) make a difference
Old Feb 11, 2005
Not sure, I wrapped my header with the heat wrap, coated that with the thermo tec spray, AND modifed my oem heat shield to fit over my dc header. It DEFINATELY cooled down the engine bay significantly. The header never cracked either.
CdkoInU, What's up by the way! How's the front sway bar I sold you working out?
Old Feb 11, 2005
civic01vtec's Avatar
yup.
Old Feb 11, 2005
that was a VW owner.........wasn't somebody on here.
very funny though
Old Feb 11, 2005
Hmm so I should try and get the paint off with alcohol? Will the spots where I ported get rusty?
Old Feb 11, 2005
dont' worry, it will burn off
Old Feb 11, 2005
lol okay thanks
Old Feb 11, 2005
jdmtytedoridori
i have a vp, but same thing
Old Feb 11, 2005
jdmtytedoridori
Hmm, perhaps ill check it out.
Old Feb 11, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I know of many headers that glow red during operation. Formula cars, high power turbo, etc, but a stock manifold should not glow. Gearbox, if you ported the inside of the header I honestly wouldn't worry about it rusting, as it will have a good coating of carbon about 30 seconds after you start it for the first time.
Old Feb 12, 2005
Thank you!
