the car-puter is under way
Old Jan 17, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
ive decided to go on with my dorky car computer idea. I just cant wait to have 160gb of hd mp3 music and dvd video at my disposal! Not to mention the wireless high speed transfers and web surfing i'll be doing (well, at least from my driveway for now . Ive got eveything I need including a 7" wide screen vga lcd monitor and a 300watt power inverter.
Now.. its time for the hookup. I wanna stick the pc in my trunk, and run all the wires for the input devices to the front. that straight forward enough. my biggest concern is how this sucka is gonna power on.
Most simply, i would run a speaker wire up to the front of the car from the pcs power button...but then i started thinking- it would be nice for the pc to turn on when i turn the ignition. how would i go about doing this?? should i use some sort of relay? will my battery be able to handle turning the engine over and powering the pc up at the same time??
thx.
Old Jan 17, 2005
909's Avatar
909
909 will become famous soon enough
I would be wise not to crank over a inverter powered PC.
If you insist on surviving crank, invest in an opus.
Old Jan 17, 2005
tfnaaf's Avatar
BLDNPSI Mod
mp3car.com
Old Jan 17, 2005
SOHC's Avatar
an opus? whats that?
does it cost a lot? if it does im screwed!
Old Jan 17, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Ive had mine for over 3 years in my car =)
Old Jan 17, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Opus is a DC-to-DC power supply designed specifically for automotive computing. THe reason 909 suggests it is that it's able to supply voltage even through the voltage drop created by cranking your engine, thus saving your carputer and its components. It'll cost you roughly 2 bills.
ComputerGuru
Mar 5, 2011 11:36 AM
