HP Racing header...lagging
Old Jan 20, 2005
  #31
djmota's Avatar
I have been running the Hp header with thier o2 sim for 4 months with no problem, no rubbing, and nice gains. I think if I did not have motor mount inserts the header would hit the front of the subframe a bit.
Old Jan 20, 2005
  #32
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
Originally Posted by jrock2324
I had my hp header and cat for like 1 year and a half now. And nothing is wrong. I have it on a LX.
From your profile it says you have an Apexi S-AFC. The HP guy said i might need one of those. What's your experience with this mod, and why did you originally get it?
Old Jan 20, 2005
  #33
djmota's Avatar
I originally got it to get the most out of my mods...an extra 5 hp or so with a nice fuel curve. You can run without with no troubles, but if you want that little extra. Then I say get it, and get it tuned.
Old Jan 20, 2005
  #34
ManUtd0018's Avatar
What did you pay for it?
Old Jan 20, 2005
  #35
djmota's Avatar
300.00 for vafc2
but safc2 will be cheaper at around 260-280 ish
Old Jan 21, 2005
  #36
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
hey what you'all used to trim the subframe?????...
Old Jan 21, 2005
  #37
ManUtd0018's Avatar
I used a torch to burn off part of the frame. Get it glowing then chip it off. Be sure to paint the cut part with high temp paint so that it won't rust. Also wait til it cools a little before painting. If you don't have a torch i'm sure a metal file will work, but it'll take you a while to do.
Tell me if you find a blue wire on rear o2 sensor. The directions say to run the long blue wire from the front o2 sim to the rear o2 sensor. then to cut the o2 sensor's blue wire and connect the long blue o2 sim wire to it. I didn't find a blue wire on the o2 sim. the only thing i found was a black, gray, and two whites. HP said to take it to a performance shop to have them do it. I was so mad. I said, " if it's for my model car why can't you provide accurate directions?" The guy gave me BS. So i cut the sims off and there's no lag.
Old Mar 22, 2005
  #38
ManUtd0018's Avatar
Just to rectify this, HP gave me Lexus is300 directions and two sims. I thought it was the same application, but it wasn't. installed one sim, reset the bugger, and it runs fine.
case closed.
Old Apr 2, 2005
  #39
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
HAHAHAHAHAHAA.....When I installed my HP header w/ high flow cat, the only problem I had was it rubbing on the frame and having a leak caused by the donut gasket but all is now fixed and everything runs fine..Oh yea and I didn't even install that o2 sim box...LOL...my check engine light never even came on
Old Apr 2, 2005
  #40
kornsined's Avatar
so what's the overall verdict on this header? is the performance only high end? i'm expecting it's the usual minimal gains.
Old Apr 4, 2005
  #41
HeHateMe's Avatar
HeHateMe is an unknown quantity at this point
My directions didnt say that. my HP Racing header/high flow cat came with just "one" o2 sim box for the rear sensor. You don't mess with the front o2 sensor,the front o2 sensor adjust your air/fule mixture.The rear o2 sensor just monitors your cat.I also had to grind some of the sub frame too. HP Racing's o2 sim is retarded, none of the wire colors match mine.
Old Apr 9, 2005
  #42
ManUtd0018's Avatar
Exactly, their wires are hellof retarded. The header itself works great. Top end power mostly. low end is kind of weak until vtec kicks in, and to be honest it still feels that it lags at 6500 rpms in second, although barely.
Old Aug 25, 2005
  #43
jmx148's Avatar
jmx148 is an unknown quantity at this point
i got the hp header and high flow cat but they never included any sim box my emission light comes on and goes off should i call them and see why i got no sim?
Old Aug 25, 2005
  #44
HeHateMe's Avatar
yeah I would, it should come with one.
Old Sep 6, 2005
  #45
ManUtd0018's Avatar
Yes, it should come with one o2 sim for free.
Old Sep 20, 2005
  #46
WKHCivic's Avatar
WKHCivic will become famous soon enoughWKHCivic will become famous soon enough
So is this or is this not a good set of headers for an auto lx. Also can you all tell me what you think of this set up, these headers with the hi flo cat and magnaflow exhaust. Appreciate it guys thanks.
Old Oct 10, 2005
  #47
WKHCivic's Avatar
bump
Old Oct 10, 2005
  #48
kornsined's Avatar
it'll give some extra jump but nothing crazy.
Old Oct 10, 2005
  #49
WKHCivic's Avatar
Will the hp headers with hi-flow cat and the magnaflow cat back exhaust bolt of and fit correctly.
Old Oct 11, 2005
  #50
HeHateMe's Avatar
mine's an auto lx too. I would get a EX cat back. I have the GReddy EVO 2 catback...it bolts right up to the HP header/high flow cat.
Old Oct 11, 2005
  #51
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
ok so about what i know the hp wouldnt be any problem for the lx/dx ,
the hp fit also on a ex here is is about my install i have it about a year now
and have no problems.
people say that you need to cut out some of the front motor mount.you could
do this but its not nessery just remove it problem fixed
but some have a problem that the header gets in contact whit the subframe
and will gif vibration on the car.this i wat i did ,just cut some metal of the
frame and no more vibration.
than the installing went pretty quick
so about the o2 sim console that comes whit the header.it doesnt need to
be installed.you will see that the engine light will come on.so i kept driving
around like that and the light would come on and go out.than i resset the ecu
and after that it didnt came on.
If i have been working on the car and disconect the neg. wen everything
is put back togehter and i start the car i came on did a reset and it was
fine again and has been for a year.
Old Oct 11, 2005
  #52
WKHCivic's Avatar
Ok so if i get the hp headers wtih hi flo cat and the magnaflow catback exhaust everything will bolt up and fit fine since the catback is for lx or ex? Also i noticed that in the pictures just posted it was on an 04-05 and mine is an 01 is this a problem?
Old Oct 12, 2005
  #53
DaRk_MauL's Avatar
it makes no differince if it is a 01-03-04-05 ex
Old Oct 12, 2005
  #54
Danger Mouse's Avatar
Tejas PimP
Danger Mouse is just really niceDanger Mouse is just really niceDanger Mouse is just really niceDanger Mouse is just really niceDanger Mouse is just really nice
So what you all you guys are saying is that the HP High Flow Cat has issues w/ being a direct bolt on like the manufact says it is... is it really wise top be removing your motor mount or even cutting into the frame... I mean, hell, the motor mount in there for a reason.. to keep the motor in one place.... after reading this thread I am actually considering sending my stuff back to truehonda.com.. I don't to have to alter stuff in that way.. chaning bolt ons is one thing.. taking a torch to my car is a complete different subject!
Old Oct 12, 2005
  #55
HeHateMe's Avatar
you only remove the motor mount to put the header on..mount the header,then you put the motor mount back on.
there's no issues with the cat..it bolts right on to your cat back.
Old Oct 12, 2005
  #56
Tejas PimP
Ok.. I can understand taking the mount off and putting it back on... but there was a couple of people saying that one or the other was rubbing agianst something and to keep that from happening they where cutting into their frame to reduce noise...
Old Oct 12, 2005
  #57
ManUtd0018's Avatar
True, one of the primary tubes will hit against the subframe; and, without doing anything it will be super annoying. You don't have to torch the subframe but that's the easiest way. You can buy a file and file that sucker down too. No shop will do it for you because it would be considered a liability if they weakened the substructure at all.
Old Oct 12, 2005
  #58
Tejas PimP
that seems a little dumb to me that, HP or anyone for that fact would release a product that does not fit properly... hopefully the guys that will be helping me with the install can figure something out...
So what was the consensis on the O2 Sensors from HP.. do we need to use them, or does it not matter? Just trying to get all my ducks in a row before the part gets here.
Old Oct 12, 2005
  #59
HeHateMe's Avatar
thats because HP's is a 4-1 style. my friend has a 4-2-1 on his 04 civic...no rubbing at all. mine only rubs the sub frame when I slam on the brakes
I don't have my o2 sim box installed, but the CEL comes on every now and then.
Old Oct 12, 2005
  #60
WKHCivic's Avatar
I notice that all of yall have ex. I have an 01 lx is it still gonna fit. How does it work with magnaflow catback exhaust and this header and hi flow cat?
