led install
Old Dec 19, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
led install
aight so i did a search and i found these directions for installing an led
WITHOUT ALARM
1. Use a light tester and test each of the slots available in your fuse box. The circuit that turns on while the Key is out of the ignition is your CONSTANT (+) and the circuit where it only turns on when there is a key in the ignition and shut off while you remove it is your POSITVE SIGNAL (+).
2. Ground the Black Wire to the chasis.
3. Connect the Yellow Wire (+) to the postive 12V signal(+).
4. Connect the RED wire (+) to the constant 12V (+)."
i have remote entry and would like to set the led to begin its blinking when i turn the car off unfortunatly my led's have 4 wires.
yellow= constant
black = ground
blue = negative (alarm status)
orange = + 12v
how do i do this install so when i turn the car off and take the keys out the lights beging to blink? thanks for the help in advance. i would prefer not to have a toggle switch to have to control the led.
Old Dec 19, 2004
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
y would an led just blink on it's own?
Old Dec 19, 2004
nunzio42's Avatar
Anyone know which this is? i tried to find one but i cant find something that is on when the key is out and off when the car is on. HELP
Old Dec 19, 2004
gtracing's Avatar
TeLLy is my daddy
i don't think there is one...hahahaha try using a relay or something
Old Dec 22, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
are you sure you tested all your fuses? The has got to be a constant (+) in your fuse box, a positive signal should not be hard to find.
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
