Oil Leak
Old Oct 16, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Oil Leak
What could be the cause of engine oil leaking from in between the tranny and the engine, i just got a used engine swaped in since i blew the old one.....
Another issue is some smoke is coming out from in between the stock header and my downpipe, could it just be a bad seal since it does not smell like burnt oil
Old Oct 16, 2004
Jaykuai's Avatar
ish...
just get a cupra. :P
Old Oct 18, 2004
I ve got no $$$$$
Old Oct 18, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
You may need a new oil pan seal. Did you remove or replace the oil pan?
Old Oct 18, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
If its leaking between the engine and transmission its either a rear main or the oil pan. Replace the donut gasket on the stock manifold between it and the downpipe.
Number 14. About $15.
Old Oct 18, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Yeah and by the way rear main on the civics is prone to being bad and leaking Its a defect but of course they wont recall it.....HAH
Old Oct 21, 2004
it coudl be the main cause i replace the gasket when i installed the oil pan, and ill check the donut gasket and see if a new one is all that different if not, ill just use some silicone gasket maker...
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
davidpaustin
May 20, 2015 12:59 PM
