I searched and found 3 old postings regarding the Drive Right CarChipE/X but nothing indicating anyone had tried it. Has anyone given the product a try? If so, comments???
Thanks
RR
Thanks
RR
are you talking about a performance chip like the ones found on ebay for like $5?
No this is a chip that installs in the OBDII connections that monitors trip time and date, distance, speed, hard accelerations and decelerations, and engine diagnostic trouble codes, RPM, throttel position etc.
f^ck chips they don't work, you don't find anything about them because everyone knows they are just stupid resistors added to the ecu and do absolutely nothing.
You generally don't use chips until everything else has been done to the car. Should be a last mod if at all.
Quote:
Originally Posted by Pharoh
You generally don't use chips until everything else has been done to the car. Should be a last mod if at all. and most of the time you should never be done with the car, you will always want to tweak it in some other way. And most of the time get tired of it and move to another car before you can get anywhere near being finished.
Wow did you guys even read his post? He’s not talking about a performance chip. He talking about a chip that monitors his cars performance not one that actually enhances it.
Quote:
Where do you see a description of the chip in his post? Originally Posted by Ksaness02civic
Wow did you guys even read his post? He’s not talking about a performance chip. He talking about a chip that monitors his cars performance not one that actually enhances it. Quote:
Thanks
RR
Originally Posted by RedRider
I searched and found 3 old postings regarding the Drive Right CarChipE/X but nothing indicating anyone had tried it. Has anyone given the product a try? If so, comments???Thanks
RR
Quote:
Right hereOriginally Posted by Pharoh
Where do you see a description of the chip in his post? [QUOTE=RedRider]No this is a chip that installs in the OBDII connections that monitors trip time and date, distance, speed, hard accelerations and decelerations, and engine diagnostic trouble codes, RPM, throttel position etc.[/QUOTE
I c....I wasn't replying to that post specifically.
Yeah your post isn't the one I was talking about either yours was actually helpfull but masters post was pointless IMO.
WOW---getting back to my original question. Has anyone used the CarChip E/X that monitors car performance?
RedRider good job searching 1st man.. Give this man a hand
Quote:
but yeah back to ur question. lol.Originally Posted by RedRider
WOW---getting back to my original question. Has anyone used the CarChip E/X that monitors car performance? sounds a lot like the apexi rev meter... the gtech meter too..
u should check on those, the gtech is a bit more popular.
Hey CapYoda..Thanks Man. For a second I thought I was asking advice from a couple of Pep Boy employees
the vafc2 lets u monitor a whole bunch of stuff like rpm, throttle, intake pressure, air correction, vtec signal from ecu, vtec signal to ecu, vtec cam angle advance, and battery at teh same time letting u adjust ur fuel and vtec engagement and stuff...
