Updated FINISHED Attempting return fuel conversion soon(pics inside)
Old Jun 25, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i am attempting to convert my returnless fuel over to a return setup...i am waiting on a couple more things to come in from Street Level Performance and then i will get started on it...i will make a FULLY detailed DIY with pictures for everyone...i know that there are a couple on here, but some dont have pics, and the ones with pics are not complete...but here are few pics of what i have and i am using
pics are of my fpr, fuel preasure gauge, and my modded fuel rail...also going with walbro fuel pump, and earls stainless braided line...it is going to be nice....
ID:	31677   Click image for larger version
ID:	31678   Click image for larger version
ID:	31679   Click image for larger version
Old Jun 25, 2004
SquirrelCivic's Avatar
SquirrelCivic is an unknown quantity at this point
damn , you got those pics up quick. yeah , thats the same fpr i was looking at . pics look nice though dude .
Old Jun 25, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
awesome, pics are what make a DIY possible. any DIY I post will have pics.. I just don't see the point (this day in age) of trying to explain something so detailed in just text.
Old Jun 27, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
nice man...let me know when we can do mine
Old Jun 27, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
That custom kit is gonna be stellar like
Old Jun 27, 2004
andyman97's Avatar
Turbo Guru
Yeah, if he can ever get his hands on a turbo, lol.
Should be nice, btw, have you done a leak/pressure test on the rail to make sure the weld is leakproof? Before you put it on, I'd test it to 125 psi at least. Did you have the weld job done local?
Old Jun 27, 2004
opto_isolator's Avatar
Personally I would have it brazed on. The fuel rail is "sweated" together - and if you try and weld a fitting on, it may cause problems due to the heat. I had my fitting brazed on and had no issues with it at all...
Old Jun 27, 2004
andyman97's Avatar
Turbo Guru
I agree. It's always a smart idea to test it for pressure and leakage before install, though. It's no fun to put it back together and have a leak, then start from scratch.
Old Jun 27, 2004
jwcardy's Avatar
the welder and i took that into consideration...he chose to weld it because a weld is stronger than brazing, and he also stated that the temp he would weld it at would still penetrate both metals but would not be any hotter than what a torch would be when brazing it on...he also stated that the fuel rail would come apart before the weld leaked...
Old Jun 27, 2004
tfnaaf's Avatar
BLDNPSI Mod
was that tig welded? It looks like a REAL clean weld. Id imagine if it was tig welded it would generate less heat then brazing, but i could be wrong.
Old Jun 29, 2004
yes , it was tig welded
Old Jun 29, 2004
HyaBoosta's Avatar
what modification is done to the fuel rail. is that additon for the return fuel line?
Old Jul 11, 2004
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Hey guys if you are using that reg. then u dont need to mod the rail. its a bypass style. i set mine up with that one last year, 6k miles ago works mint. after serious hacking of the sending unit assembly i got a walbro pump in there and bypassed the factory reg. just drill a hole in the top of the sending unit and tap a brass pipe elbow into it to hook to the return. when its apart you can see where it should go. dont forget to change over to high pressure line from the pump to the top of the unit. there are two hoses originally, only use one from the pump to the top of the sending unit and find something to seal off the other one. there is a fuel filter that is built into the top of the sending unit. make sure you hook up the line so the fuel flows through the filter. leave enough slack in your hose so the sending unit will still move. its hard to get everything back into the tank so be patient. its a pain but with some common knowledge of fuel systems and some hacking skills you can easily do it
Old Jul 12, 2004
orso's Avatar
orso is an unknown quantity at this point
um yeah i think a diy is a must because i have know idea how to do this, but it sounds like it is worth it.
Old Jul 12, 2004
slowcivic's Avatar
slowcivic is an unknown quantity at this point
hey If u need a turbo pm me or email me at dcs161616@hotmail.com. I have a brand new t3/t4 stage 3 sittin in my room. Its made by precision turbo. I bought it for 800. Ill let it go for 400 obo.
Old Jul 12, 2004
Your Parts Guy
He bought one just recently.
Old Jul 12, 2004
jwcardy's Avatar
pics of what is going on...just a sneek peek
ID:	32746   Click image for larger version
ID:	32747   Click image for larger version
Old Jul 12, 2004
HyaBoosta's Avatar
pretty sexy
Old Jul 12, 2004
jwcardy's Avatar
Jeff from streetlevelperformance.com is driving in from florida this weekend to help me complete it...we might also be putting on some tokicos too
Old Jul 13, 2004
HyaBoosta's Avatar
take tons of pics!
Old Jul 18, 2004
jwcardy's Avatar
hey guys...return fuel conversion is complete, and i have to say that it looks AWESOME....Jeff and i are in the process of making a DIY, and when we finish, we will post it up...until then, stay in the edge of your seats....
Old Jul 19, 2004
HyaBoosta's Avatar
PICS?? is this the set up that Street level performance is going to sell?
Old Jul 19, 2004
Your Parts Guy
Yes
Old Jul 19, 2004
HyaBoosta's Avatar
How did it go with the install? any word on price? PICS
Old Jul 19, 2004
orso's Avatar
hey where are these pics you promised.
Old Jul 19, 2004
HyaBoosta's Avatar
they are in another post.
Old Jul 19, 2004
Your Parts Guy
Price coming very soon.
The install was flawless. Everything went exactly as planned. We experienced no problems whatsoever.
When the install was complete we used a hex key to adjust the fuel pressure back to stock. The B&M gauge kit really helped us dial it in.
Can't wait to see that AEM Gauge-Type UEGO Controller installed Wes!
Old Jul 19, 2004
HyaBoosta's Avatar
thats tight. when your workin the the gas tank is it best to keep it full so there are less igitable fumes, or less so there no mess and less fuel everywhere. Oh and is there any way to get a list of items used?
Old Jul 19, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
Is this setup just for turbo civics? what are the benifits on a stock 2002 LX? would it increase power on a stock car?
Old Jul 19, 2004
Your Parts Guy
It can be used on ANY 7th gen civic excluding the SI. There is no increase in power it is used to allow you to make more power with future modifications. With the kit you will be able to control the fuel pressure from the FPR under the hood. This is not possible with the existing returnless fuel system without adding an inline pump.
