100K What needs to be done?
Old Jun 7, 2004
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
I have about 4K more miles to get to 100K miles. What things need to be done, besides: oil, oil filter, air filter cleaning (FIFKII), sparkplugs, brake fluid, brake check, flushing water/coolant.
Transmission Oil (auto) most recent replaced at 75K.
Does the car have a fuel filter that can be replaced with out dropping the tank?
Do I need to replace the Coils?
Other recommendations on what other things to do?
Thanks.
Old Jun 7, 2004
zen_master's Avatar
definitely, your timing belt....
Old Jun 7, 2004
Pharoh's Avatar
Bobaganoosh!
Valve adjustment
Old Jun 7, 2004
EManEX's Avatar
Right, thanks!!
Originally Posted by Pharoh
Valve adjustment
Where can I do this? Can I just take the head to any engine shop or does it need to be done at a Honda dealership?
Thanks.
Old Jun 7, 2004
Pharoh's Avatar
Bobaganoosh!
Originally Posted by EManEX
Right, thanks!!
Thanks.
I would say any reliable shop. I'm getting mine done at Honda this week. They told me it's $40 (canadian) if they check and it's not needed but if it is then you just pay an hour labor which is $72 Canadian.
Old Jun 7, 2004
zen_master's Avatar
sorry for being noob..
however, im still confused about....the valve adjustment...what is it, actually?
Old Jun 7, 2004
Pharoh's Avatar
Bobaganoosh!
Tighten the valves in the head to factory specifications. They can become loose over time and need to be adjusted. It's part of the 96,000 km warranty servicing on the 6thgen but they don't do it on the 7thgen so you have to get it done out of pocket
Old Jun 7, 2004
zen_master's Avatar
um...
what and where is the "valve" that we're talking about? hehe....*sorry*
Old Jun 7, 2004
EManEX's Avatar
The valves in the head.
Old Jun 7, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
The valves and valve seats wear slightly after slapping each other for a long period of time, like 100k on new cars. You just remove the valve cover, set a cylinder to TopDeadCenter (valves closed), and use feelers to check valve clearance. ~15 minutes depending on how much you have to adjust. You hardly ever do this on new cars with hardened valve seats, but we check our datsuns (1971,1972) annually.
Old Jun 7, 2004
EManEX's Avatar
Whats a feeler?
How about the coils? Should I replace those?
Old Jun 7, 2004
Sickboy's Avatar
Feelers are just thin pieces of metal (almost like a popsicle stick), that are of different thicknesses that you stick under the cam lobe to determine its clearance. Anyways, I'd just pay a mechanic if you haven't done it before. I can't help you with the coils, I don't know enough about these Direct Coils yet. Good luck.
Old Jun 7, 2004
Storm897's Avatar
Storm897 is an unknown quantity at this point
Valve adjustment
Greys DIY: Valve Clearance Adjustment
Old Jun 7, 2004
Storm897's Avatar
Thanks.
Try this site for maintenance info on a 2001 Honda Civic EX
MamaBear2015
Sep 24, 2015 11:34 AM
Manuel Depaz
Sep 23, 2015 03:43 AM
slammed925
Sep 13, 2015 11:27 PM
rayman009
Sep 12, 2015 08:30 PM
fred57
Aug 1, 2015 08:45 AM
