Overheated engine
Old Mar 30, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
Overheated engine
"K24 short block, needs to be rebuilt. from a 2004 accord with less than 800 miles on it. engine was overheated, i recomend having a machine shop go through it but is rebuildable."
What is this person talking about? Correct me if I am wrong but aren't engine blocks pretty much bullet proof? If I am going to replace the pistons, crank etc shouldnt things be ok or can the walls get "scared" and mess up everything. I like all help =p thanks guys.
Old Mar 30, 2004
clownprince's Avatar
Ricerus Maximus
that walls could have been scarred up and possibly some things damaged, but I'm sure some parts are still good. If you bought it I would just take it to a machine shop. Plus you would need to redo all seals and everything.
It would probably end up being a pretty massive project.
Old Mar 30, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
short block = without head
overheated probablly means that the pistons/rods/crankshafts are messed up in one way or another...
Old Mar 30, 2004
Texas Rice's Avatar
I really don't care about pistons/rods/crank because all of those will be replaced. But what you are telling me, is that you cant be sure without pictures? =p
Old Mar 31, 2004
J-spec-SiR2's Avatar
J-spec-SiR2 is an unknown quantity at this point
short block is without head... alt intake man header everything pretty much not in the bottom end
Old Mar 31, 2004
Texas Rice's Avatar
"no theres no scaring on the cyl walls, but looks alittle scorched (glazed) it looks as tho u could just hone it, the crank is turnable but i think it spun a rod, it still turns over pretty easy."
The seller said that back to me when asked about the cylinder walls. So if I plan on replacing the pistons, crank, and rods I should be good right? Also, should Im going to go ahead and take it to a machine shop just incase but what do you guys think that will cost, repairing "glazed" cylinder walls? Thanks for the help guys.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
zaboomafoozarg
May 30, 2015 09:21 AM
deus-ex
Apr 13, 2015 12:29 PM
