Installing side skirts??
Old Mar 15, 2004
DareDebil911's Avatar
DareDebil911 is an unknown quantity at this point
Did you guys have to jack up your car when installed your side skirts or rear bumper, I'm gonna be putting on my Xenon sides and rear, and I am wondering what the easiest way to install these would be.
Old Mar 16, 2004
OniChi's Avatar
OniChi is an unknown quantity at this point
It's easier if you install them when the car is jacked up.. so more room for you to work with.
Old Mar 17, 2004
Maverick's Avatar
Maverick is an unknown quantity at this point
Just jack the car up from the rear to do the sideskirts, screw into the fenderwells and use very strong double sided adhesive in the door sills...you can also screw here as well if you prefer, but i didn't. If your car is lowered, you may have to use your stock jack to jack up the sides then put a bigger jack next to that once you get it up enough, then you can install your rear. It's not necessary to jack up the rear, but it does give you a more comfortable working area. You may or may not have to take out your rear lights...the first time i installed I did, the second time I don't think i did. Good luck.
Old Mar 17, 2004
So, did you just jack up the rear and turn the front wheel to get the sideskirts on?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Youshoe
May 22, 2015 09:36 PM
1slo2k1civic
Nov 21, 2001 11:07 AM
3rdcivic
Oct 24, 2001 12:19 PM
