Diy grouping question
Old Dec 20, 2003
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
QUESTION:
Who updates the DIY section on the side of the entrance page?
THERE ARE SO MANY diys on this site that are AWESOME! (mainly by grey) that are not listed on the side of the site.
Is there any way we can begin to get them posted on the side of the entrance page (under the diy section?)
Old Dec 20, 2003
I don't know if that is possible. There are literally hundreds of DIYs on this site. I know, because I wrote some of them. Try searching only titles for DIY and you should get alot of them.
Maybe someone can make a list and post it with a sticky that has all the thread names?
Old Dec 20, 2003
Maybe a mod can sticky this and members can add to it. This is a very short list I just put together.
DIY: custom pedals
DIY: Trunk shocks
DIY fuel kill switch
DIY grounding kit install
DIY Blue glow needles
DIY power windows for hx/dx
diy return style fuel system
diy installing rear speakers in sedan
diy making dash lights brighter
diy atf change
diy aluminum door sills
diy installing SF turbo kit
diy my custom audio setup
diy spark plug install
diy LED gauge swap
sound deadening diy
sidemarker diy
diy factory head unit removal
diy full auto detail
diy store your summer wheels
streetglow diy
door panel diy
diy install turbo timer
diy progress front sway bar
diy triple air horns
diy ground control coiloves
diy no more trunk rattle
diy shutting off defrost mode during A/C
diy brake pads and rotor install
diy power steering fluid
diy push button ignition
diy amp wiring 2k1civic coupe
diy painting washer nozzles
diy booty call
diy hood pins install
diy throttle body heater bypass
diy oil gauges
diy replacing pollen filters
diy reverse indiglo gauges
diy box carpeting
Old Apr 18, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
Old Apr 18, 2004
zen_master's Avatar
hehehehe
a very good list, thanx gearbox!
Old Apr 18, 2004
NeonImpact's Avatar
Forum Sponsor
what about my 2003 center console removal..
Old Apr 19, 2004
IrockCivics's Avatar
I'm interested in:
DIY push button ignition
DIY painting washer nozzles
DIY making dash lights brighter
Thanks.
Old Jun 10, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
nice
Old Jun 10, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Derek is in charge of updating the DIY's... Grey has all of his listed in his sig, so if you need them, just refer there...
As for the rest, I know that Derek just started working on the section a short time ago so I'm sure more will be added over time....
Also, check the DIY forum...
http://www.7thgencivic.com/forums/fo...play.php?f=109
Tedverseti
Apr 23, 2020 01:45 PM
