DIY for tranny removal
Old Dec 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
COMe'N SOOOOON.....
Hey guys... apparently i have a bad bearing on my main input shaft so i removed my tranny today... im gonna make a DIY as soon as i take more pictures and re install it .....
So be READY!!!
heres a taste of what im doin..
OH and reason for this is to prove some people wrong when they have stated that the sub frame must be removed...
up.. i see subframe and no tranny..
Old Dec 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
imp:
Old Dec 16, 2003
blustrek01's Avatar
blustrek01 is an unknown quantity at this point
yep been there and done that already!!!!!!!! it sucks dosen't it? why didn't you remove the axles all the way? i thought it was much easier than trying to manuver around them? what is all the wiring hanging down? i didn't have all that when i did mine. oh by the way i've done mine twice. it sucks to be me. have fun!!
Old Dec 16, 2003
Mr.Modify's Avatar
oh sweeT! good job and good luck
Old Dec 16, 2003
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
You are a better man than I. I couldn't get it out. Good job.
Old Dec 16, 2003
clownprince's Avatar
Ricerus Maximus
Nice, that will definetly be a good DIY for when I go to replace my clutch/flywheel
Old Dec 16, 2003
acidbaby's Avatar
The Beez Kneez
dayam wicked diy
Old Dec 16, 2003
AudioQuest's Avatar
AudioQuest is an unknown quantity at this point
Wouldn't that be a warranty issue?
Old Dec 16, 2003
PunkingCivic's Avatar
I need TP for my bunghole
pop a new performance clutch while you have it out and if you can afford it.
Old Dec 16, 2003
Elite's Avatar
Elite is an unknown quantity at this point
OOOOhhh He took out the battery thats the trick!
Old Dec 16, 2003
opto_isolator's Avatar
Yeah, battery, radiator hose, airbox......etc. Seems like a lot of work just for the tranny. I'd probably still drop the subframe (as honda intended) - lot less crap to worry about when putting it back together.
Old Dec 16, 2003
Elite's Avatar
I dont really necessarily call it crap, but necessary parts, and really its just nuts and bolts, I've taken off my subframe before and I know its really hard to do especially by yourself, there i like no way you can put it on, by yourself
Old Dec 16, 2003
Elite's Avatar
oh btw I still see the radiator
Old Dec 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
theres already an extreme act setup in there .. why do u think its yellow..
and all that wiring is called the ENGINE wiriing harness.
lmao and warranty issue.. lmao here .. this can answer ur question..
http://www.7thgencivic.com/forums/sh...o&pagenumber=3
Old Dec 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
remove the axels? lmao.. just pull them out the tranny with a screw driver and ur fine.. theres no reason to remove them. ever.
Old Dec 16, 2003
civic01vtec's Avatar
sweet, i cant' wait for this diy
Old Dec 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
its commin... i just gotta wait til i put it back in again. lmao.. im just busy or it would have been done...
tranny removal time was only about 2 hours tops.
Old Dec 16, 2003
7thGenerasianCivic's Avatar
very nice...lol
Old Dec 16, 2003
Jodster's Avatar
Post Whore General
Less crap to worry about? Do it that way then tell me how much of a pain in the *** it is. I took the tranny out of my old 01 EX by taking out the subframe. Oh there is more than the sub frame to take out, like the down pipe of your exhaust, 3 of the 4 motor mounts cause they are connected to the sub frame. Getting the sub frame to line up to connect the control arms on the install was a b*tch. Don't for get about the 20 something suspension bolts you have to take out and torque back correctly. I never thought about taking the tranny out from the top because I followed Hondas way too. I'll never do it that way again. Ask Chris(Prod) about taking the tranny out of my old 01 EX. He helped me with it. It was not an easy job to do. Too many parts to take out. Took about 12hours total. And that was with 4 guys. I can't wait to see this DYI. It will be very helpful for when I take my tranny out of my 03 EX.
Old Dec 16, 2003
Dr5D's Avatar
yikes, thats all ive got to say... I would not try that myself
Old Dec 16, 2003
djmota's Avatar
pefect diy for the guy that does not have a lift.
I look forward to this one. Replacing the clutch and flywheel has always kinda scared me. hopefully after this the fear will be gone.
Old Dec 16, 2003
JDMsicvic's Avatar
JDMsicvic is an unknown quantity at this point
yeah ive taken my tranny out 6 times...i installed a ACT clutch and 10 lbs flywheel.....and i always had a problem with the engagement each time, then my tranny went bad..so i had to take it out and replace the bearings inside.......I know my tranny inside out.. lol...but this would be a great DIY .....keep up the good work
Old Dec 18, 2003
Jodster's Avatar
Post Whore General
Update!?!? Wheres the DIY??
Old Dec 18, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Im assuming that you have a heated garage. Cuz its damn cold outside!!!!
Old Dec 18, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
no heated garage.. its not that cold... ... im waiting for my new tranny in the mail... DIY will be done soon !
Old Dec 19, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i changed my clutch without removing the tranny from the engine bay once cause i knew removing the subframe would be time consuming.what did you have to do to remove it from the top?
Old Dec 19, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
the diy is comin dont worry...
all u gotta do is pull that bitch up. lol well not really.
Old Dec 30, 2003
Jodster's Avatar
Post Whore General
Any updates?
Old Jan 15, 2004
k20a1emcivic's Avatar
-=* I LOVE MEN*=-
k20a1emcivic is an unknown quantity at this point
lol its been a month and no updates or a diy
Old Jan 15, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
lol i forgot . hahah ill make one up tonight and post it tomorrow night sometime.. sorry guys.. its coming.
