cel header
hey guys i have a question about everybodys check engine light coming on when they put a header and downpipe on does that hurt the engine and what does it mean why does it come on all i know is it has to do with the 02 sensors thanks for the help
it puts the car into some kind of "safe mode" so its not getting all the right settings that the ECU normally uses when the light is off. I would imagine you are losing power with the CEL on because its limiting factors like fuel delivery, etc.
and my other question guys is there anyway to prevent the cel from coming on once you install a downpipe w/ free flow cat like any type of different 02 sensors or anything i dont want an 02 sim by the way
I have the HP Race w/hi flo cat. I got a CEL 2 trips after install and reset ECU, got another CEL 2 trips after reset. Reset again and it didn't come back.
THERE IS NO NEED FOR AN o2 SIM!!!
Pull the F.I/ECU fuse in your engine bay when you get the CEL 2 or 3 times and it wont come back. It is a learning computer, there is no need to trick it with an o2 sim.
If you dont want to reset the ECU go ahead and pay 50+ for the sim.
Good Luck.
Good Luck.
Originally posted by RiceBuRNeR
you dont even have to reset the ECU just drive around for a day or 2 and it will turn off.
Prowlin' with a Purpose
mine turns on after like 50 or so miles after i reset it, im told that you can use an o2 sensor for the front in the back to override the CEL... i will let you know in a few days
When it threw the CEL for the hiflo cat, it didn't put the ecu into limp mode, I still had regular fuel maps. Full potential..im not positive but i think it only puts the car in limp mode for certain codes...depends on what your problem is. It WILL go away..
well.. my cat is a straight through design.. at least i think it is... cause i can see through the entire pipe, it keeps throwing a code i dont know what the problem is.. i guess ill drive it around for a while and see, but my friend and i are working on an o2 simulator, but we kind of are stuck on the wiring diagrams.. would someone like to point me out to the ecu wireing diagram so i can figure out the RIGHT wires to splice into?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
